01-21-2010, 05:30 PM | #1 |
Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Hey guys i was reading on another thread about how to modify stock tracbars and make home made shock relocators. We mass produce the perfect solution to both these issues and they work like a charm. The shock relocators come 2 lowers and 2 uppers powder coated with the mounting hardware. Before we try to reinvent the wheel e-mail me and i will give you a deal on a rear kit and get you down the road. Remeber guys just ask me for anything and if i have it , i want it on your truck!
01-22-2010, 12:45 AM | #2 |
Re: Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Cool pictures...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-22-2010, 11:46 AM | #3 |
02-04-2010, 09:11 PM | #4 |
Just a car guy
Can you explain to me the benifit of this?
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
02-04-2010, 10:01 PM | #5 |
In a nut shell the less angle on your shocks the more efficient they are
02-04-2010, 10:02 PM | #6 |
Active Member
After you lower the rear suspension the shocks will be mounted at a large angle, kind of like there laying down. The shock looses its abality to work when it is like that. The relocation brackets remount the shocks so they are more upright. This makes the shock work better at controlling the suspension movment.
Danny Nix CPP |
02-04-2010, 10:17 PM | #7 |
Just a car guy
I see. Do you still use the same length shock?
02-04-2010, 10:50 PM | #8 |
low n' slo
whats the price on these jeff? and where would you mount the top one if your using a step notch?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-05-2010, 11:31 AM | #9 |
02-14-2010, 06:15 AM | #10 |
I've got grease on my mind.
Do you have some pics of the kit installed? I am using your 4" drop springs and the shocks are just about laying flat. What about new U-bolts? Are those in the kit? Do you recommend using degree shims as well?
02-15-2010, 11:48 AM | #11 |
I posted a pic of them installed above, they do not come with the u-bolts as you can use your originals with this kit. We do sell the pinion shims also if you need them. Thanks
02-15-2010, 12:43 PM | #12 |
vw guy & now c-10 guy
Hey Jeff, I have a problem- I had to cut my old track bar mount (on frame) to get the old track bar off (bolt was seized in bushing) - do you guys happen to sell the frame mount bracket? If so, let me know, I need to order one up! thanks brother!
02-15-2010, 02:48 PM | #13 |
I might have one let me ask danny and see what we have. Thanks bro!
02-15-2010, 05:32 PM | #14 |
thanks man, just let me know...
02-15-2010, 05:55 PM | #15 |
02-15-2010, 06:13 PM | #16 |
I saw that pic but the lower bracket is not the same as your kit. It looks like a block where the shock mounts. I thought is was mounted to the trailing arms because they look aftermarket as well.
02-15-2010, 06:36 PM | #17 |
Hey do you have a pic of what you are describing? I would like to look at it. Thanks
02-15-2010, 06:42 PM | #18 |
OK. Can you see the block? What much are the U-bolts and shims? Is there something like a 1/2" to 1" block with shim built in?
02-15-2010, 06:46 PM | #19 |
02-15-2010, 08:08 PM | #20 |
Cool!!! I'll give you a call tomorrow
02-15-2010, 08:56 PM | #21 |
02-15-2010, 11:08 PM | #22 |
Nothing to see here.....
got mine!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
02-16-2010, 04:38 PM | #23 |
Hart Rod's are almost straight up and down,mine are still laid over like tcb-1's. Is this because I am using the stock trailing arms?.Ideally I would like my shocks behind the housing,but still trying to figure out how to do that.
02-16-2010, 06:28 PM | #24 |
TCB-1S and mine are correct, they will lay slightly over but not on there side.
02-24-2010, 04:04 PM | #25 |
does anyone actually have a before and after pic of the set up, and possibly a pic of the bottom side of the bracket? would be great to see, thanks
67 chevy 402 BB w/ TH400 Learning as much as i can before i dig in!! |
