69 Fleetside
![]() Join Date: Mar 2009
How much HP do I need for easy passing at 60mph?
I am looking at swapping in a new engine or rebuilding the tired 307 in my 69 long bed. I used to have a Subaru STi that would run 13.0 in the 1/4 all day long, not fast by any means, but great fun on the street. I absolutely loved the passing power it had, and it was put to good use lots as we have some property on the other side of the mountains. We make 2-3 trips a month, and the roads are single lane highways nearly 3 hours of the trip. With that said, I want my truck to have the same passing abilities as there are many occasions where it is needed. I can't imagine any rebuilt 307 letting me pass comfortably so I think a new 350/355/383 in going to be in order.
Now back onto the question. My truck has 3.08 rear gears, and a TH350 tranny. I debate on the "cheap" GM crate 350 with 250hp/350ft-lb's but just think it can't/won't breath enough to make passing quickly a reality. Do you folks think the Blueprint 355 w/310hp and 360ft/lbs would be enough or do I need to save a bit more and step it up to 375hp/400ft-lb 355? Or even blow that out of the water with a 383 pushing 400hp/450ft-lbs? I just don't know what to do at this point, and don't have enough seat time with this old ride to know what I need for power. Any ideas or thoughts from your experiences? Thanks |
Re: How much HP do I need for easy passing at 60mph?
That's a loaded question... lol...
May be good to ask in the performance section though. |
dont sell yourself short on power
ummm.....13 seconds in the 1/4 is pretty good for a street car. only factory vehicles that will beat that are a corvette, viper or some exotic supercar.
it all depends on weight, transmission, tires, hp and tq, etc etc and a ton of other variables (as well as driver finesse) to get good performance numbers out of any vehicle. even the dodge ram with the viper package wouldn't break 13 seconds (0-60 in 5) due to weight, aerodynamics, balance, etc. |
I have a 383 in my 67 and it has great passing power. My other car is a Speed 3 ( Modified to 300 hp ) The truck has as much passing power a different feel though.
Good luck with your project. |
swap the 3.08 for a 3.73. it won't hurt gas mileage much and it will be night and day. the 3.08 is just plain lousy in a truck without a huge engine. it would be awesome with a diesel and work good in a stroker engine that doesn't pull big trailers.
I've had a couple of fast street cars (corvette and 3 LS1 firebirds) and now a G8 so I know what you mean.
Back in the day my 72 GMC had 3.08 gears and a TH350. I had a 327 in there that was putting out around 300HP and it had respectable passing power. |
#8 | ||
Redefining LowBudget
I'll let you know how this goes I'm makeing a gear change but IMAO 3:73 is a great all around gear...my 308's such except on the highway.. Quote:
now if you want decent power and want to have fresh power I would put in a vortec out of a truck with a carb ( bolt in stuff) that will be a big improvment then go for the gears....I'm doing gears and putting vortec heads on my 327 that should wake it up to be a good street pounder with decent mileage until I fine a caddy for real power
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
you'll need atleast 600HP for a "good passing" experience
![]() Last edited by 68 short step; 01-21-2010 at 09:47 PM. |
Big Red - Now its a SWB!
You know what they say, you can never have too much money or horsepower
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#11 | |
To get back on subject a worked up 383 would do nicely.
68 GMC 91 GMC ext cab 05 Dodge Ram SRT-10........gone but not forgotten |
#12 | |
http://community.webshots.com/user/hotrodhorn |
#13 |
![]() Join Date: Jan 2008
Just put a 150 shot to it, it will have plenty of passing power with the push of a button. Just kidding....but it would work!
#14 |
69 Fleetside
Hehe, I had some good laughs there guys - good info. I have honestly thought about the 3.42 and think that it will probably be a good middle road to head down, but for now, am stuck to the 3.08 until it breaks from my new engine or I save up the cash for a 5-lug axle swap, new gears, and a posi/limited slip diff. From what I hear, I better suck it up and get the hot 355 or a 383. I will be going over a mountain pass hauling 2 dirt bikes, lots of gear/gas/tools and still having to pass people constantly as they can't seem to go the speed limit - at least 2 weekends a month - so power is a must have...I appreciate all the thoughts and comments guys!
#15 | |
#16 |
"THE GREEN GOBLIN"
I have a 454BB & Th400 with 3.73's in my 72short bed and I think I got some good passing power I even get sideways at times when I put my foot down I love my Kickdown
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#17 |
I agree with SCOTI. You are looking at the wrong variable in the equation. If speed is what you are after you build a motor with horsepower in mind. But Torque is what moves you when you need to be moved. With you having the 3.08s you are more high geared for running on the hwy and to equal out the get up and the go with that set up you need more push. With you driving plans I would recommend the 383. Its got the best of both worlds, just pay attention to you cam specs. You'll want an engine that stays fairly close if not in the power band at your cruising rpm. Say you are crusing at 2200-2400 and your engines peak torque hits at 2800-3000 rpm, you will be scooting pretty good once the go fast pedal is layed down. But as we all know HP/Tq go hand in hand. My vote is for the Stroker
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
#18 |
I had a V-8
I have about 230hp and 650+ft/lbs of torque. Even in a 6500lb vehicle, I have no issues whatsoever passing or pulling 7% grades over 75mph. I would shoot for something around those numbers--they work well for me.
Not much power, but a bunch of torque = fun vehicle to drive!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
#19 |
ENGINE BUILDER
YOU NEED TORQUE not HP! My truck has a cheap 383 I built out of parts I had sitting around and the TORQUE it makes is unbelievable. I have 3.08 gears and 29 inch tires and I don't even NEED passing gear. I just did another one for my 68 C-20 that I will install in the springtime. I plan on using it to pull my car trailer. Just do a nice simple 383 and do not over build it. You will not be dissappointed! If you want my opinion on the details just PM me.
JIM ZAG |
#20 | |
What everyone seems to be overlooking here is the transmission. Torque is exactly what you need, but you don't need excessive amounts all of the time, it just costs you in fuel milage. Torque multiplication comes from the gearing....transmission and rear differential.
Going to a lower gear (say 3.73) and then an over-drive transmission (say 700r4) that will bring the RPM back down for cruising will serve you best in all respects. It will allow for good passing power and still good mileage.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#21 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-22-2010 at 01:00 PM. |
#22 |
Wrong question. How much can you afford?
You can never be too rich, too pretty or have too much horsepower. This one passes everyone just fine. Uphill, downhill, or pulling a two ton trailer. Just doesn't matter! |
#23 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-22-2010 at 03:51 PM. |
#24 |
I am a Referee of life.
I think you should build a plan.I would go with an OD tranny,a 383, and 3:42 gears.You may have to do one at a time to afford the upgrades.Modern GM drivetrains are usually set up as a 350,4L60E and 3:42's.The 4.3 engine gets the same driveline gearing(Standard).The GM engineers have done a lot of work to come up with a good combo for performance and economy,but the added torque of the 383 will feel really nice either under your right foot or your butt.(Seat of the pants)
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#25 |
69 Fleetside
The main problem is that it just sits in my driveway and collects mold. I have finished the interior and paint and just want the damn thing running and movable. I have a 2010 YZ450F that is sitting in my garage begging to be ridden, but doesn't have a truck to take it over the mountains ...
It is truly budget driven at this point and I want/need it up and running by late spring so I don't have much more time/money to save. I have about $4000 now that I can spend on the engine and tranny combo, and this is full turnkey, as everything currently is 40 year old scrap and I don't trust it one second on our 4 hour trips to our property. A new 450hp handling PA TH350 tranny with converter/fluid/dipstick is going to run me about $1000 so that leaves around $3000 for an engine. For about that, I could order the 310hp/360ft-lb Blueprint 355 from Jegs for $3200 with almost all the bolt ons and call it a day - but second guess that decision as I think it might not be enough. A 700R4/200R4 that can handle 400-450hp is going to blow my budget out of the water and leave me with nothing for an engine, as I would need to swap gears at the same time or just be lugging any engine I put in it - I would love to but my budget says "nope". Another thing I need to factor in is gas mileage, which changes this whole equation. It is about 250miles door to door, so a gas miser Edelbrock 1406 strapped to a 355 might be the best bet there, although my uncle gets 14-16 with his 383...so who knows...too many options to consider and ideas to weigh... Last edited by Beatcoaster; 01-22-2010 at 06:28 PM. |
