Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-21-2010, 07:39 PM   #1
vegaschevy
What media to use in sand blaster?
I picked up a sand blaster form harbor freight to do my control arms, now I need to get some media. What do you recommend?
what grit and media to do control arms and heavier metal things btu not be too heavy to do other things?
vegaschevy is offline   Reply With Quote
Old 01-21-2010, 08:20 PM   #2
BarryB
BarryB's Avatar
Re: What media to use in sand blaster?
I got my blast media from Tractor supply, Black diamond, it was like 8 bucks a bag. does good for this type of stuff. Just hook up a shop vac to the cabinet so you'll be able to see what your doing.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-21-2010, 08:35 PM   #3
vegaschevy
What grit? also any other options from anyone?
Old 01-21-2010, 08:59 PM   #4
cdowns
cdowns's Avatar
with harbor frieght you need to use stuff thats not too aggressive because the real heavy duty stuff will eat up the hose and gun that they supply
bagged blasting sand in very fine grit should do the job good
Old 01-21-2010, 09:08 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
walnut shell
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-21-2010, 09:39 PM   #6
suville
suville's Avatar
One of the nicest profiles I've experienced was with copper slag if you have a powder coating facility in your area check with them on purchasing some they use it a lot because of the very clean and smooth surface it leaves or as the trade terminology is "profile" it will only need one good coat of primer sand seal and paint. I used to spend hours and countless 80 grit DA discs to knock down the profile from "sand" blasting. Give it a try you'll never use anything else, I sure dont!
suville is offline   Reply With Quote
Old 01-21-2010, 09:45 PM   #7
msgross
msgross's Avatar
I used Black Beauty Coal slag - medium grit... $10 per 50 lbs (i think) and not as dangerous as sand (silicosis). I had a harbor freight sand blaster and the valves lasted about 20 minutes and wore out... I'd be ready to pick up a new deadman gun from tractor supply and some new valves. Be sure to have a water filter on your compressor..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-22-2010, 01:19 PM   #8
63 & 64 Bowties
and a few others
My brother and I just did a 70 Mach 1 that we're restoring to sell. We used a $150 Northern Tool blaster and about 400 lbs of Black Beauty Med grit. Worked great.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 01-27-2010, 04:50 AM   #9
vegaschevy
the valves are in the gun I am assuming? it seems to not work as good as it did. I have no problem replacing the gun with something better to get good results.
i wonder wher ein Vegas i can get a bit of coal slag.
