01-21-2010, 10:17 PM | #1 |
front drums to disks on front of 6 lug '64-'66 Chevy C10 truck
I have a customer that wants to convert the front drums on his '64-'66 Chevy C10 with factory six lug hubs to disks. Besides the new kits offered by CPP and the likes, are there any front cross member donors that are available from a donor truck? He is very budget conscious, so a donor with six lugs and disks is the major criteria. He also has six lug steelies he is keeping, so six lug is a must.
I attempted a search, to no avail. Thanks in advance for your input. |
01-21-2010, 11:06 PM | #2 |
Happy to be here
Re: front drums to disks on front of 6 lug '64-'66 Chevy C10 truck
I don't know of any 6 lug disc donors. Everything that is an econo swap is 5 lug. The cheapest solution I know of are the 6 lug drum to disc conversions.
01-21-2010, 11:12 PM | #3 |
67-72 parts collector,…
The cheapest way to get 6-lug discs is to you any donor truck from 73-87 that is 5-lug.
Then all you need is a set of aftermarket 6-lug rotors from companies like ECE, CPP, Brothers, etc. |
01-22-2010, 03:41 PM | #4 |
Tot Roddin'
One other thing to consider Tony is that if/when you swap over to disc brakes up front the trac-width will be 1.5" wider overall. Depending on the size of the steelies, they might stick way out up front when compared to the rear, or they might not be able to clear the caliper.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-22-2010, 07:23 PM | #5 |
I'm just glad to be here!
There is a way with factory parts to do a 6 lug swap. I am not 100% sure but here is the parts you would need. There is also a thread in the 60-66 forum that has this info buried in it...
Lower control arms from a 67-70 3/4 ton truck Upper & lower ball joints from a 88-98 chevy C-2500 light duty Spindles from a 88-98 C-2500 light duty Rotors from a 88-98 c-2500 light duty (they are 6 lug factory) Caliper and hoses from a 88-98 c-2500 light duty outer tie rods from a 88-98 c-2500 light duty you will also need an adjuster sleeve to adapt the tie rods to the stock inner tie rods, I think you can get them from Fatman Fab... Hope this helps.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-22-2010, 10:02 PM | #6 | |
Never Ending Projects
Oh, and starting in '92 or '93 (Can't recall) the 1/2 ton and light duty 3/4 ton use the same spindles, hence why you can swap rotors for a lug pattern change.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-23-2010, 01:20 AM | #7 |
I have all the parts off a 72 that you would need. They just came off my 72 C10 project and I don't want to store all this extra stuff.
All redone (bearings, pads, rotors, drum cylinders, etc) with less than 500 miles on 5 lug disk brakes and rear 5 lug drum brakes. Parts on westcoast. PM me if interested. |
02-05-2010, 03:36 PM | #8 | |
Still plays with trucks
The offset on the front rotors may not be enough to work with rear wheel drive offset wheels but the rear are much more offset (1.13 to 1.47" more depending on rotor design) and could just do the trick. It might even be enough to run 15" wheels. Combine these with some generic caliper brackets from DIY4x4 or anybody else and a set of 1.25" rotor truck calipers plus fabricate an adapter bracket to connect the caliper bracket to the spindle mount points and you are in business. The Tahoe rotors are $40 to $56 each vs. $69 each for the C2500 LD rotors so combined with not having to change out your ball joints & source good spindles this could be a less expensive way to get 6-lug front disc. You could also use the Tahoe dual piston calipers too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-21-2010, 11:30 AM | #9 | |
Somebody found that if you use Moog part number ES2020R/L inner tie rods with the adjusters and outer tie rods from the C2500 and shorten them about 3/4" that it will bolt up to the older center link and allow proper alignment. Supposedly the lower A-arms from 67 to 87 3/4-tons will work with the lower ball joints of the C2500. The 1/2-ton C-10 lower A-arms use a smaller OD lower ball joint so they will not work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 02-23-2010 at 12:21 PM. |
02-22-2010, 09:12 PM | #10 | |
Active Member
Danny Nix CPP |
