01-22-2010, 08:41 AM | #1 |
intermittent starting issue
Subject: 1986 C-10 4.3 w/ factory Q-jet.
Issue: If you just pump the throttle by mistake just once when the engine is still warm it will not start. After waiting a few hours for the engine to cool off it will start will no problem. New coil and ecm installed last year. Solution:?
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck 1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac |
01-22-2010, 11:36 AM | #2 |
Robert Olson Transport
Re: intermittent starting issue
my first thought would be to inspect the linkage and make sure that its properly working, and the butterfly is. When you flood a carbbed engine you can take a screwdriver and hold the butterfly open and it will start with the gas pedal fully depressed.
01-22-2010, 10:26 PM | #3 |
haha, ford guys...
on the passenger side of your carb,there should be a little plastic can looking thing with a vaccc hose going to it. inside is an thermostatic spring.
it has prob. went out, replace and let us know. should cost 5 bucks and 5 minuets, |
01-22-2010, 10:38 PM | #4 |
THe choke is likely stuck on.
