Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-22-2010, 11:02 AM   #1
MONTE
MONTE's Avatar
BBC motor mounts?
I'm putting together a 454. I recently got some super comps headers 2841.
What motor mounts do I have to use to make this happen?
MONTE is offline   Reply With Quote
Old 01-22-2010, 05:47 PM   #2
Alex1
Alex1's Avatar
Re: BBC motor mounts?
I assume it would be using the factory BBC mounts.
Alex1 is offline   Reply With Quote
Old 01-22-2010, 07:46 PM   #3
MONTE
MONTE's Avatar
would i have to use later model mounts? 73-newer?
Old 01-22-2010, 09:11 PM   #4
ripdog28
ripdog28's Avatar
ECE sells some tubular mounts which worked great for me. my headers are about the same as far as fitment.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-24-2010, 01:27 PM   #5
69trk
69trk's Avatar
I have the same headers. I used the tubular mounts also. Fit great..
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 03-08-2010, 05:31 PM   #6
Wildstreak
"something witty here"
Wildstreak's Avatar
@ripdog28 do you have the part number for the ece tubular motor mounts? I tried searching the site but had no luck.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 03-08-2010, 08:32 PM   #7
MONTE
MONTE's Avatar
i used performanceonline.com
ECM6372.
Big Block Chevy
