Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer > projects and builds
Old 01-22-2010, 12:32 PM   #1
Butcherboy
Butcherboy's Avatar
The 5.3 Blazer build
Howdy, names Justin from Kansas. Im in the middle of a 1988 Blazer 2wd 2dr 5.3 swap. I have taken the truck down to the frame, and now building up from there!
Thought Id start another build thread here. You guys have been very welcoming to me and my questions. Thanks!
So here it go's!
Justin
Butcherboy is offline   Reply With Quote
Old 01-22-2010, 12:37 PM   #2
Butcherboy
Butcherboy's Avatar
Re: The 5.3 Blazer build
Size:  55.7 KB My stand alone harness I did myself with the help from you guys!
My shop
Size:  60.5 KB the new chassis harness.
Old 01-22-2010, 12:42 PM   #3
Butcherboy
Butcherboy's Avatar
Justin
Old 01-22-2010, 12:46 PM   #4
Butcherboy
Butcherboy's Avatar
Justin
Old 01-22-2010, 01:06 PM   #5
kdhs10
kdhs10's Avatar
Lookin good, I may be getting a S-10 with a slightly built 5.3L here pretty soon.
kdhs10 is offline   Reply With Quote
Old 01-22-2010, 06:28 PM   #6
Damien
Damien's Avatar
Nice work so far.
What are you using for a water pump? I thought the water pump on the truck engines had clearance problems with the LS1 intake.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-22-2010, 06:47 PM   #7
Butcherboy
Butcherboy's Avatar
Originally Posted by Damien View Post
Nice work so far.
I ran into to problem. I found out that the 2007 or newer Silverado water pumps will clear the throttle body. I also had to mod the idler pulley location to below the alt. The old idler mount had to cut off the truck drive unit bracket.
Here is a picture of the idler relocation mod. Also a longer belt was needed. I think something around 102 inches. Took me 3 attempts to get the right belt!
Justin Hope this answers your questions! I also had to add washers behind the pulley and use all thread bolt and locker nut!
Old 01-22-2010, 09:25 PM   #8
Damien
Damien's Avatar
Sweet. I'm sure there are a lot of guys that would like to know about the water pump. Is it cheaper the the Ls1 water pump? Oh I like the wiring harness laid out on the cutting board too. Kinda appropriate.
Old 01-24-2010, 11:00 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Glad to see you have a build thread here! That LS1 intake looks right at home there!
GM changed the waterpump on the trucks, so the 07 and up make a great replacement for anyone wanting to put an LS1 or LS6 intake on the Vortecs. It eliminates the clearance issue with the throttle body, especially on the electric ones. And you don't have any alignment problems with the new truck pump also.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-25-2010, 02:06 AM   #10
Jonce
Jonce's Avatar
Looks like a fun build
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 01-25-2010, 03:30 PM   #11
Butcherboy
Butcherboy's Avatar
Thanks for hooking me up with the Intake Bob!
The water pump a little pricey but still cheaper than vette or F-body FEED!
The harness work was the most time consuming. I bought the relay box from current and the Injector plugs from EFI Connection along with other plugs and connectors. Really wasn't that bad doing all the work, just had to take my time! Still saved me about $600 bucks doing it myself.
Just moving along with the Chassis harness now. I found a lovely family of mice in my dash! They ate up almost all the insulation on the wires, and started on the hard plastic! I live in the country, and that's Life!! Just hate the smell of mouse piss!
Sunday I ripped what was left of the old wiring, and should have the new wiring in this week! The only thing I need is parts blazer, manly the dash and hard plastics. I missed one this weekend, 89' 4wd 2dr blown engine for $200 bones! Clean old truck, inside was spot less!
Another Question Bob. Who did your computer tuning? I'm thinking Fast Chip might do mine. But thought I'd ask you and others who else?
Thanks again!
Justin
Old 01-25-2010, 03:43 PM   #12
glock35ipsc
Jesse at wait4meperformance.com has done all mine for several years now. I think it is $75 to reprogram your PCM, and about $175 (don't remember for sure) if you don't have a core and buy one programmed from him. To rework the harness and reprogram the PCM is $360.
Bob
Old 01-25-2010, 05:16 PM   #13
Butcherboy
Butcherboy's Avatar
Woo! That's cheap! Is that just for the vats and Emission? Or dose that include add on like my LS1 intake- injectors, headers and a aftermarket tachometer? That is my only question. I haven't decided on a cam yet. But would like to have a bump stick in it! The transmission for now is a Fresh built TH-350" left over from my Nova that sold last year that was never put to use", but I plan on a 4l60E later.
Any help would be great! Thanks
Justin
Old 01-25-2010, 05:22 PM   #14
glock35ipsc
That is for whatever you need reflashed in it. Oh, and free re-tunes for life, so later when you decide to do a cam, he will just need the cam specs and cam reflash it again accordingly. The PCM's tach output works with aftermarket tach's when they are set to the 4 cyl position.
Best bet is to call and talk directly to Jesse. They are a little slow at answering emails sometimes, but he will talk your ear off on the phone!
Bob
Old 01-25-2010, 05:24 PM   #15
Butcherboy
Butcherboy's Avatar
Thumbs up Re: The 5.3 Blazer build
Thanks Bob! I just called Wait4 Me. Wow! That $75 at first sounded to good to be true! I will get it out this week!
Justin
Old 01-25-2010, 05:43 PM   #16
glock35ipsc
I hope I had the prices right, it's been while since I had just the PCM done.
Bob
Old 01-26-2010, 11:40 AM   #17
Butcherboy
Butcherboy's Avatar
Post Re: The 5.3 Blazer build
You where right about the prices. Just was hard for me to believe at first!
Justin
BTW How did you rigg up oil sending unit? Pipe thread tap the drivers side oil cooler adapter?
Old 01-26-2010, 11:51 AM   #18
glock35ipsc
Yup!
Bob
Old 01-26-2010, 12:18 PM   #19
Butcherboy
Butcherboy's Avatar
Thanks Bro!
Old 01-27-2010, 06:17 PM   #20
Butcherboy
Butcherboy's Avatar
Hey Bob I have question! When you sold me that intake. I didn't notice it at first, Its missing the threaded inserts for the throttle bracket. You would have them laying around somewhere or know the PIN number for the Sealership? I bought a billet Lokar Ls1 cable mount and can't bolt it on!
Justin
Old 01-27-2010, 06:24 PM   #21
glock35ipsc
Ya know, I never noticed. I have a drive by wire throttle body, so I guess I never had a reason to look. I shipped it to you in the same box I got it in, so I know they aren't here. if all else fails at a dealer, there are a variety of threaded inserts available that you can install. Most work like a pop rivet, and swell up as you tighten the bolt. I used them all the time when I was building conversion vans. I even used some on Fred to attach the bracket I made for the MAF to the radiator support.
Some examples:
Bob
Old 01-27-2010, 06:29 PM   #22
Butcherboy
Butcherboy's Avatar
When in doubt, ask Bob! Thanks buddy!
Are those easy to find? Where else besides the Dealer?
Justin
Old 01-27-2010, 06:39 PM   #23
glock35ipsc
Believe it or not, our ACE Hardware has them. I think NAPA and CarQuest does too. If you have a fastener supply place close by, like Fastenal, they will definitely have them.
Bob
Old 01-27-2010, 06:45 PM   #24
Butcherboy
Butcherboy's Avatar
Yeah, I just called Fastenal here down the street. Just need to figure out what thread size and count now! You wouldn't know the bolt size by chance? Thanks again for the help!
I'm really ready to get this show started! Reaching almost a year since I started this project. Budget hasn't went to high as of yet. 70% finished, and still under $2.500.00! Still got the important stuff left yet!
Old 01-27-2010, 07:09 PM   #25
glock35ipsc
Eeks, I really wouldn't know for sure. But if I had to guess, I would say the bolt size was around 4mm, maybe 5mm. Might be easiest to make that SAE, it might be easier to get an insert for SAE threads, #10 or 1/4". If you can, measure the I.D. of the hole and see what they have that will fit in there.
Bob
