Old 01-22-2010, 06:10 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Do I need this heads? Tell me if they look good...
Going to build a motor for my truck someday and Im collecting parts. Found some heads. They were 'redone' at some time. (20 Years..lol) never been on a motor. They have 'the big valves' '4barrel heads'. Are they somthing I should put on my budget 350 build? Im looking to spend NO MORE than 1000-1300 dollars.
So far Ive found myself
4bolt main block no machine work yet
edelbrock high rise alum. intake (not sure exactly what type)
500cfm carb. (just rebuild may try to find somebody to trade for slightly larger holly or edlebrock.
still undecided on the rest
I THINk I have a steel crank, how can I tell (was told it was out of BIG truck)
He's also got some heads just like em(too lazy to run #'s) but I can.
there not 'redone' yet he said he'll trade me for my extra qjet carb.
good trade what should I do
He wants $150 for worked heads (ones pictured)
John
1999 Toyota Tacoma 4x4
Old 01-22-2010, 08:05 PM   #2
oldblue1968chevy
Re: Do I need this heads? Tell me if they look good...
3973487X...71-72...350..........1.94/1.5 or 2.02/1.6 valves, 75cc chamber
this is what I found on mortec
sorry im a newb can somebody unscramble all this and tell me if this is a good buy or a good #? ima pick em up and let the local machine shop take a look see at em...I think i trust them lol.
anyone?
thanks
John
Old 01-22-2010, 08:55 PM   #3
Indyuke
They're an ok buy, unless they do in fact have the 2.02" intake and 1.6" exhaust valves.
75cc chambers with the smaller valves, 1.94" intake / 1.5" exhaust will be the low compression, more restrictive flowing "smog" heads. Those are common.
Indyuke is offline   Reply With Quote
Old 01-22-2010, 09:09 PM   #4
roughedup72
roughedup72's Avatar
just by looking at the pics they look like they haven't been machined very well.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 01-22-2010, 09:33 PM   #5
truckdude239
truckdude239's Avatar
well he said they been sittign for 20 years after being done i would let the machince shop clean them up a bit and check the vavles
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-22-2010, 10:01 PM   #6
cdowns
cdowns's Avatar
aset like that around here freshly ported polished with screw in rocker studs go for about $200-$250 a set
those heads look like they came out of a junk pile and someone took a sanding disc and wire brush to them
Old 01-22-2010, 10:21 PM   #7
leddzepp
Moderator
leddzepp's Avatar
x 2. Another thing to consider is how long before you actually build a motor. If it is not going to be for a while, why bust out $150 now for them to sit on a shelf? There will be plenty around when you actually are going to start. Good luck with whatever you do.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-22-2010, 11:21 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
i would at least let a machine shop check them for cracks and other problems before you buy them
Hubscrub is offline   Reply With Quote
Old 01-22-2010, 11:22 PM   #9
oldblue1968chevy
OK, thanks all I needed to know
Will have you guys 'review' my set ive already got tomorow.
John
Old 01-25-2010, 12:56 PM   #10
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Those definitely do not look like 2.02's. 2.02's have about 1-2 credit cards width between the valves in the combustion chamber.
Be wary buying old heads. Old heads made during the years of "leaded fuel" do not have hardened valve seats. New unleaded fuel in old heads without additives contribute to increased wear in the seats.
suprachrgd82 is offline   Reply With Quote
Old 01-25-2010, 01:14 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If it were me I would pass on them. They are not 2.02s and look to be just standard truck heads. To top it off they look to be in need of some pretty good machining due to the rust pictured and probably hardened valve seats for unleaded fuel. Another unknown factor is how were the valve guides done? Knurled or bronze guides installed? You can probably buy "off the shelf" heads from summit or jegs cheaper than you would have invested in those when done. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-25-2010, 01:54 PM   #12
oldblue1968chevy
ok really will be thinking vortec just hate to put more money down for an intake to match lol
John
Old 01-25-2010, 04:15 PM   #13
au03z71
au03z71's Avatar
Well, the heads shown look very suspect. It looks like somebody took a die grinder to them to knock the patina off the gasket surface. At the very least, you'd need to get them magnafluxed and probably decked due to the shoddy grinding on them. Also, if they've been setting for 20 years, it wouldn't be a bad idea to get new valve seats. IMO, it would definitely be in your best interest to invest in some good heads. You can get a set of Patriot Vortecs and run your old style manifold if you want.
au03z71 is offline   Reply With Quote
Old 01-25-2010, 04:28 PM   #14
oldblue1968chevy
patriot vortecs huh..
wat'll they run?
John
Old 01-25-2010, 04:53 PM   #15
au03z71
au03z71's Avatar
wat'll they run?
They're about $650 a set fully assembled. You're probably going to pay half that to have those old heads magged and decked (more than that if they find out something else is wrong with them). I have a set of Patriots and have zero complaints. You can run a roller cam setup if you want and you'll get much better flow than those old style heads. Vortecs are going to be the best bang for the buck. I'm fairly confident everyone will agree with me there, I wouldn't spend the money on older heads, but that's just me.
Old 01-25-2010, 05:22 PM   #16
MESS-HALL
MESS-HALL's Avatar
I found em' for $450.
https://www.patriot-performance.com/...&cat=76&page=1
And these will work on my ole' 350? With the current intake?
oh...........and those heads are not worth what he's asking.
GROVE STREET CUSTOMS est. 2005
67' C10 LWB/350/T400
69' C10 SWB/454/T400
71' C10 LWB/383/
72' C10 SWB/350/T350
15' Crew Silverado/6.2
MESS-HALL is offline   Reply With Quote
Old 01-25-2010, 05:48 PM   #17
au03z71
au03z71's Avatar
That's the link to the BARE heads.
Old 01-25-2010, 06:01 PM   #18
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hello, those heads look like 882 heads. Most all the old open chamber heads are prone to cracking. I would wait and see what piston you are going with. If you build a flat top motor and go with those heads you are going to have a very low compression ratio. Even if you deck the block and slice the heads and you use a thin head gasket you will be lucky to have 9.1 CR. JMO
Camaro_nut2001 is offline   Reply With Quote
