Addicted to Rust
![]() Join Date: Dec 2009
Ls swap oil pan ?s
Any one use the F body ls1 pan on a truck engine? With the 5+ inch static drop the truck pan makes me nervous. Will the car pan clear the cross member with the engine in the "Fred" position. Thanks Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Re: Ls swap oil pan ?s
I have a 5" drop on my 86 up front, no issues with my 6.0/truck pan. But it's not my dd either.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
Happy to be here
![]() Join Date: Mar 2000
It will depend on the motor mounts you are using. On my 82 Blazer we used S&P mounts and had no issues with clearance. The only concern was the a/c compressor in the stock location. We had to clearance the frame to make it work.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-22-2010 at 09:00 PM. |
Addicted to Rust
The control arms and bottom of the cross member are 3 inches off the road. I am not sure how much drop that is. Jay
ya, I forgot to mention...245/40/20 tire size...too lazy to do the math...
that would also make a difference.
Next project: 1970 K10
Many swaps over on performance trucks.net and ls1truck.com have been done with the f-body pan. No fitment issues that I have heard of.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
![]() Join Date: Jul 2003
Check this out Hart_Rod did a ton of research and work.
http://67-72chevytrucks.com/vboard/s...d.php?t=272174 |
#8 | |
Addicted to Rust
How did I miss that one on the ol search. I can get a f body pan and the assorted pieces for 125. so I am gonna give it a try. Jay
Hey Jimmy read the whole thread. CTSV pan may be better.
This might be another option for you?
http://www.crateenginedepot.com/stor...3-P2410C0.aspx
All that for $136?!?!?!? Wow!!
![]() This kit allows Muscle Car enthusiasts to use a LS Series engine in the older style car or trucks. # Fits virtually all 1955-1995 GM front engine, RWD, V-8 cars # 5 qt capacity # Includes oil pan, dipstick and tube, gaskets, pickup tube, windage tray, and all mounting hardware # Wet sump design # This kit is not a direct fit for the LS7, LSA or LS9 engines # Use oil filter P/N PF 48 89017524. ![]()
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-23-2010 at 01:01 PM. |
Addicted to Rust
Man that looks like the trick and a good deal. Jay
#13 |
It brings the oil level down to 5 quarts though. Looks like GM part I wonder what it is by application.
#14 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
I used the LS to gen1 adapter plates and my stock 6.0 oil pan is about 1/2 inch below the crossmember. I dont see it causing any issues at all.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#15 |
Addicted to Rust
It sits pretty low with the short 17s on it
![]() Your 20s probably are a bit taller. I am planning on new wheel but it will be a little later on as the budget allows. Jay
#16 |
Mine sits about 2-1/2" below the cross member. Stock 06 truck pan, original 85 towers, clamshells and rubber mounts, 1/4" adapter plates.
#17 |
Even better deal at www.gmpartsdirect.com. Go there and search part number 19212593. The one the pcmcobra posted is a factory GM kit for universal applications, and GM Parts Direct has it for $125.80.
![]() DESCRIPTION: PAN KIT P/N 19212593 was intended to be a universal oil pan the will fit most applications. Its a little more compact than a Corvette style pan. It fits all Gen III and IV engines and includes the oil pan, gasket, indicator tube and indicator, pickup tube and crankshaft oil deflector.
