BBC Parts
Well, my big block fantasies were dashed when I found a problem with my block. Never even got it fully assembled. To keep my 68' build project on track, I scrapped my big block plans and purchased a 383 crate motor. Now all my new big block parts must go. I'm taking huge losses on all this stuff. Prices are negotiable especially if buying more than one item. ie; heads and cam.
Edelbrock Performer RPM Marine Heads Assembled with Comp Cams valve train to support 304HR roller cam. Heads were purchased new and assembled by local speed shop. I bolted one head on the block. The other was never bolted up due to a block defect. I will throw in the correct ARP head bolts and head gaskets(a $200 value). Everything for $1800 ![]() ![]() ![]() New in box, Edelbrock Air Gap Intake - Nascar edition. This edition normally sells for over $300. Take it for $225 ![]() New Comp Cams 304HR Roller Cam w/ roller lifters. Includes timing cover that has been modified with the correct cam end play and matching Comp Push Rods. All for $600 ![]() New black painted water pump with pulleys for a 454 $40 ![]() New B&M Flywheel weighted for 454 $50 ![]() New Comp lifters, flat tappet $25 (Had these just laying around the garage) ![]() BBC oil pan with New Melling high volume oil pump. Comes with bolts $45 ![]() ![]()
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
Tightwad
Re: BBC Parts
May be interested in the water pump and pullies...depending on if short or long pump and pullies
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
Re: BBC Parts
I definitely looks to be a short pump.
![]() Join Date: Jul 2003
Re: BBC Parts
Do you have bb motor mounts?
Re: BBC Parts
No, I sure don't. I was using tubular mounts that work for sbc or bbc so I'll need them.
#6 | |
Re: BBC Parts
Actually it's a long water pump with pulleys that came off a 79' 454.
![]() Join Date: Sep 2006
Re: BBC Parts
can you give me a price on flywheel pan and oil pump shipped to 70737 thanks jimmy
Re: BBC Parts
Boy did I call that one wrong
#9 | |
Re: BBC Parts
I accept Paypal joseph@houndheaven.com or credit card over the phone (3% fee)
![]() Join Date: Feb 2007
Re: BBC Parts
pics wouldn't load for me. is that intake an oval port?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Re: BBC Parts
Yes this is an oval port intake.
Re: BBC Parts
i don't need it but it would be nice to have for a future project. $200 shipped?
#13 |
Re: BBC Parts
I will do $220 shipped. That's still over $100 below the best web price and it's new in the box.
#14 |
Re: BBC Parts
you tease. Ok i'll take it. how would you like payment?
#15 |
Re: BBC Parts
I will take the lifters. Figure the total for me and I will send you a MO. Shipping will be to 49445.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#16 |
Re: BBC Parts
I prefer payment via Paypal to ebay@houndheaven.com
#17 |
Re: BBC Parts
I will do $32 shipped. I PM you my information.
#18 |
Re: BBC Parts
So most of the small stuff has been sold. I still have the items shown below available. I'm willing to take $2300 for the Heads & Roller Cam as a package deal. That's well below cost.
Too Much Stuff: 396 pulleys and pump $40 shipped 67Mach1: Cab dolly $100 - pickup Sharpie1972: HEI $75 shipped JimKshortstep4x4: lifters $32 shipped snj8198: Manifold $225 shipped 68lowburb: Oil Pan w/pump & flywheel $110 shipped Edelbrock Performer RPM Marine Heads Assembled with Comp Cams valve train to support 304HR roller cam. Heads were purchased new and assembled by local speed shop. I bolted one head on the block. The other was never bolted up due to a block defect. I will throw in the correct ARP head bolts and head gaskets(a $200 value). Everything for $1800 ![]() ![]() ![]() New Comp Cams 304HR Roller Cam w/ roller lifters. Includes timing cover that has been modified with the correct cam end play and matching Comp Push Rods. All for $600 ![]() ![]() ![]() New black painted water pump with pulleys for a 454 $40 ![]()
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() Last edited by AusTx68; 01-23-2010 at 09:00 PM. |
#19 |
Re: BBC Parts
payment sent for the intake. PM'd you shipping info. Let me know when you sent it. Thank you. -steve
#20 |
Re: BBC Parts
PM sent.
Jim
#21 |
Tightwad
Re: BBC Parts
I am looking for the short pullies so i can use a short water pump on a 454..... What do you have for power steering set up? I would be interested in that if its set up for short water pump...
Eric
#22 |
Re: BBC Parts
As a matter of fact, I believe I have all the accessories and brackets to fit a BBC w/ short pump. Those parts along with a bunch of other stuff are in storage. I will run out today and take a few pics and get back to you.
#23 |
Re: BBC Parts
Can you give me some specs on the heads....Or a part number to look it up. What is the chamber size? What do they flow? Do they take a stock header? They look like iron? etc....
69' 3/4 4X4 470ci BBC 700 HP.... ![]() D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
#24 | |
Re: BBC Parts
Combustion chamber volume 110cc Intake runner volume 290cc Exhaust runner volume 110cc Intake valve diameter 2.25" Exhaust valve diameter 1.89" Valve stem diameter 11/32" Valve guides Manganese bronze Deck thickness 9/16" Valve spring diameter Springs Not Included Valve spring maximum lift Springs Not Included Rocker stud 7/16" Guideplate Hardened steel Pushrod diameter 3/8" Valve angle 26° Exhaust port location Stock Spark plug fitment 14mm x 3/4 reach, gasket seat Made In USA Designed for 396-502 c.i.d. big block Chevy engines, these Edelbrock cylinder heads include heavy-duty exhaust valves that provide the added durability needed for marine applications, and have one-piece, stainless steel intake valves with hardened tips and swirl-polished heads. The high-velocity flow capabilities of Edelbrock Performer RPM cylinder heads provide increased torque across a wide rpm range that's ideal for marine use. They're cast from A356 aluminum and heat-treated to T6 specs. These Oval-port heads have 110cc chambers with hard-anodizing to protect the aluminum in the harsh marine environments.
#25 | |
Tightwad
Re: BBC Parts
That sounds great i am very interested on what you have for a short water pump for a 454....I always like to see what is in storage ..you never know what you have.....I would like to have first at what you drag out..... Eric
