z'in frame
I know there are probly tons of threads on this but I'm tryin to do this from a blackberry! But all I need to know is how much do you have to z the frame to get the frame to lay flat?
Re: z'in frame
Different year models have different requirements.
Re: z'in frame
Lol oops I forgot this section is for all years! I have a 67 c-10 2wd chevy
Re: z'in frame
Well I plan on runnin a twenty inch wheel but not sure on
the tire size. I would like to keep it as close to stock as possible I'm runnin 235-75-15. |
Re: z'in frame
Your 15s are 29 inches tall.. you can run a 255-35-20 and that will only be 27 inches tall. Just to give you a idea my truck is zd 4 inches with a 3 inch spindle and plate style brackets and it will lay a 31 inch tire.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
Re: z'in frame
Sweet! Thanks for the info!
#8 | |
Texas Big Wig
Re: z'in frame
Cuz that doesnt sound big enough for the rear I Z'd mine 6" in the rear & it still doesnt lay with a 29" tall tire Last edited by Spray-Bomb; 01-24-2010 at 01:25 AM. |
#9 | ||
Re: z'in frame
More than a 3" Z & the cab really starts requiring choppin' up & there are issues w/hood clearance.
