Old 01-23-2010, 02:23 PM   #1
Sicboy
Sicboy's Avatar
Spin-on Oil Filter Adapter ?
The spin-on oil filter adapter on my '66 chevy 327 is leaking like a sieve. It's was on the engine when I bought the truck. I believe it's a Mr Gasket brand. Rather than try and band-aid the leak, which is at the top of the adapter where it meets the block, I've decided to just replace it with a new one. I've seen several different styles. Is there one that's better than the other?
Perma-Cool
http://www.summitracing.com/parts/PRM-1134/?rtype=10
Transdapt-1
http://www.summitracing.com/parts/TRD-1024/
Transdapt-2
http://www.summitracing.com/parts/TRD-1059/
Mr Gasket
http://www.summitracing.com/parts/MRG-1270/
Zip
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 01-23-2010, 03:17 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Spin-on Oil Filter Adapter ?
All I can offer is I had one that looked similar to the Transdapt-2 version shown above on a 283 in my 54 Chevy back in the 70's. Everything seemed to work fine for several months. One day I was a couple of blocks from home when I heard the engine knocking. I quickly looked at the oil pressure gauge and saw that it had dropped to zero as I pulled into the driveway.
I started checking over the engine and discovered the oil filter adapter had cracked causing the filter to loosen and fall off the engine. I was lucky, it only spun the rod bearings wiping out the crank. The block and main bearings were fine. I picked up a new crank, a set of bearings and put it back together - along with the original can style oil filter. That was my only - and last experience with an adapter.
Old 01-24-2010, 01:02 AM   #3
BMSJaX
BMSJaX's Avatar
I just had this problem a few weeks ago! First make sure that your block needs an adapter and not just a spin on mount. Mine had the adapter and didnt even need it! I replaced the cracked adapter with the spin on mount from summit and perfection, not a dip from the filter!
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 01-24-2010, 06:33 PM   #4
Sicboy
Sicboy's Avatar
Thanks for the comments guys. i've decided to go with the perma-cool option.
