Old 01-23-2010, 04:14 PM   #1
697498chevy
Question 1969 307 2 bbl Rochester
Wonder if y'all have rebuilt one lately ? Sent my off almost a year ago . Came back twice and ran for bit until accel pump came apart . Builder says he can't find a good pump . Gotta believe this guy's doing his best , but wonder if y'all have run into this . THANKS !
697498chevy is offline   Reply With Quote
Old 01-23-2010, 04:22 PM   #2
Wrenchbender Ret
Re: 1969 307 2 bbl Rochester
I've done a lot of them & never had a problem like that. Ijust did 3 for a 3 carb settup i'm building up but I havn't run it yet. I've got some of the original pumps if you want me to send you one. I wonder who's kit he is using. I did a carb for an auto display & they furnished the kit. It was junk. I always use Carquest. georgec2434@yahoo.com
Wrenchbender Ret is offline   Reply With Quote
Old 01-23-2010, 05:10 PM   #3
mike16
some of the older kits are aged beyond use and others cannot tollerate some of the chemicals in the latest batches of gas. Also some cannot tollerate the alcohol mixs.
I read somewhere but cant find the article that the color of the accelorator pump plunger determines if will tollerate alcohol.
some are too old and some are junk
mike16 is offline   Reply With Quote
Old 01-23-2010, 07:04 PM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I did the 2bbl rochester on my 67 camaro 327 (SAME CARBURETOR ON THE 307) about a year ? well I guess 2 year's ago and heve never had a problem , those carb's are old school no need to send them anywhere just go to your local auto part's and get a kit $15 buck's then take it home take the carburetor apart clean everything good and put it back together !
I did the 1 bbl rochester for my 67 C10 on my computer desk last weekend and just got back from a 4 hour drive in it today run's like brand new ,,,accelerator pump had dissentigrated !
one tip is to measure your float two or three time's double checking the level and the drop , cause too much or to little fuel in the bowl will make the best rebuild job in the world not run right ,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 01-23-2010, 07:07 PM   #5
19673ontree
CAN'T FIX NOTHIN
NAPA also has a good carburetor kit the echlin brand ,
underdash AC
Old 01-23-2010, 07:52 PM   #6
697498chevy
Thumbs up Re: 1969 307 2 bbl Rochester
THANKS for all the good feedback . WRENCHBENDER , I may take you up on your offer . I've rebuilt this carb before , after 220 ,000 miles I thought I'd let a pro do it . A few days ago he e-mailed that he was gonna try an Echlin kit . What happens when the pump comes apart the throttle jams and I'm cruising at 30 mph . THANKS AGAIN !
Old 01-23-2010, 07:56 PM   #7
19673ontree
CAN'T FIX NOTHIN
pump will not jamb the throttle it just make's it not take gas ,,
underdash AC
Old 01-23-2010, 08:11 PM   #8
697498chevy
Hate to disagree , but I know for a fact it will . Happened twice .
