Old 01-23-2010, 05:33 PM   #1
schmitty
schmitty's Avatar
air bag questions
i am planning on putting air bags on my 70. but i want them to be able to air out slow so its not so harsh and bouncy? so what affects how much air gets pushed in to the bag? i dont know if its the size of air lines, or the valves or what? thanks!!
70 c10
97 c/k1500
schmitty is offline   Reply With Quote
Old 01-23-2010, 05:40 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: air bag questions
Size of lines and valve will make a difference. 1/4" lines are easy to route. I'm using 3/8" valves because I got a deal on them but 1/4" is ok if your running 1/4" lines.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-23-2010, 06:21 PM   #3
schmitty
schmitty's Avatar
so 1/4" valves and lines would probably be what i would need to get it that way. where did you get your air parts from?
70 c10
97 c/k1500
Old 01-23-2010, 07:40 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Having had 1/4" and 3/8" systems, I feel your better off with 3/8"s. Going down slowly is as easy as inserting a piece of small line inside your large airline. They also make adjustable regulators to add control as well.
While I understand your desire for a system that drops slow, what your not taking in to consideration is the slow rise times you will have.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-23-2010, 08:05 PM   #5
Inverter
Inverter's Avatar
Use 3/8" valves & lines and put a tunable dump control fitting on each dump valve. You can adjust the drop time to your liking and still have a quick rise time that the 3/8ths line offers.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 01-23-2010, 11:45 PM   #6
Slmd92DIME
Slmd92DIME's Avatar
I have 5/8s line and 1/2 lift valves and 3/8s dump with a plug in the end of them with a 1/8 holes drilled in them to slow them down.. my dumps are perfect for me...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 01-24-2010, 11:49 AM   #7
mullit
mullit's Avatar
my sonoma has 1/2 e brand valves and 1/2 line and i use the plug witha 1/8 inch hole drilled in the dumps, couldnt ask for anything else. My burb will have 3/8 smc valves and 1/2 line. 1/4 inch lines will take tooooooo loooooong to fill.
mullit is offline   Reply With Quote
Old 01-24-2010, 11:56 PM   #8
DZL1
One day.....
DZL1's Avatar
I'm running 1/2" lines with flow controls. The flow controls are adjustable, so that you can tweak to your liking. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 01-26-2010, 12:02 AM   #9
schmitty
schmitty's Avatar
Smile Re: air bag questions
yes thank you everybody.this helps allot! i never new bout the dump controls and that is the answer for my question thanks!!!
70 c10
97 c/k1500
