Old 01-28-2003, 05:15 PM   #1
68-Mike
68-Mike's Avatar
Temp sending unit for a 68 with a 350
Where can I install my coolant temp sending unit on a 350 for a 68 C-10, with temp gauge (not switch/lamp)?
The old motor that I took out had it installed in the water neck, but prefer not to install at that location.
Where on the block/intake should I install?
Thanks in advance.
7th year of '68 C-10 LWB Rebuild in progress. Drivetrain done. Frame stripped, painted & rebuilt. Body/paint next.
'18 Yukon
'04 Sierra 4X4
‘77 Chevy C-20 Camper Special
‘68 C-10
Shopping for a 69-72 4x4 Blazer or Jimmy
68-Mike is offline   Reply With Quote
Old 01-28-2003, 05:47 PM   #2
JimKshortstep4x4
Talking
If your heads have a tapped hole, you can put the sender in the
one on the left. 69-72 had the sender located in the left head, not sure about the 67-68 location.
Jim
Old 01-28-2003, 09:16 PM   #3
crazy4chevs
crazy4chevs's Avatar
some intakes have a spot on them with a plug that you can put them in just make shure its the water passage.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 01-28-2003, 09:18 PM   #4
matt_field
matt_field's Avatar
what about if you have double hump heads-so no holes in there, and a intake but your thermostat housing is in the way? i have the same problem
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
