Old 01-24-2010, 09:57 AM   #1
67gmcstepside
2wd=2 piece drv shaft;4wd=1 piece?
Did v8 4x4's have the 2 piece drv shaft and 6 cyc have the 1? I see in the assembly manual KE109 and 209 = 2 piece and KA has a 1 piece.
67gmcstepside is offline   Reply With Quote
Old 01-24-2010, 10:15 AM   #2
1969K10
1969K10's Avatar
Re: 2wd=2 piece drv shaft;4wd=1 piece?
our 68 (LWB) I'm fairly certain came with a straight 6, but has a 2-piece DS.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-24-2010, 10:18 AM   #3
AusTruck
My 69 SWB has a one piece driveshaft. It was originally a 6 cylinder turbo 350, is now a 350 crate motor (not any HP one though) with the turbo 350. Frame doesn't show any evidence of a carrier bearing having been there, so I'm surmising it had a one-piece driveshaft from the factory. Oh, its a 2wd also.
AusTruck is offline   Reply With Quote
Old 01-24-2010, 11:51 AM   #4
67gmcstepside
Maybe is as simple as LWB = 2 piece, SWB= 1 piece. Thanks for taking the time to respond. I hope to hear from a LWB 4x4 owner.
Old 01-24-2010, 11:54 AM   #5
msgross
msgross's Avatar
my SWB 4x4 has a 1 piece...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-24-2010, 11:56 AM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I "think" all 4x4 trucks had the one piece drive shaft. Long or short bed...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-24-2010, 12:16 PM   #7
It just depends. My 70 SWB Chevy & 69 SWB Chevy, both with 6s was one piece shaft, while Krue's SWB 70 V8GMC had 2 a piece. I would Imagine all 4wds are one piece. I have yet to figure the difference on SWB 2wd why some are 1 piece and some are 2 piece.
Old 01-24-2010, 12:16 PM   #8
67gmcstepside
My issue is mine has the 2 piece and need to verify if its correct, LWB 4x4 2 piece. The assembly manual does show a pic of a 2 piece for the KE model.
Thanks.
Old 01-24-2010, 08:46 PM   #9
67gmcstepside
Does anyone have a 67 LWB 4x4 with a single drive shaft?
Old 01-24-2010, 08:51 PM   #10
ksbeatty
ksbeatty's Avatar
I have a 70 4x4 with a one piece.
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 01-24-2010, 08:55 PM   #11
67gmcstepside
Thanks, This is getting more confusing. 70 LWB 4x4 has the 1 piece. There must be a reason that some trucks got the 2 piece.
Old 01-24-2010, 09:02 PM   #12
vegaschevy
There is also 2 different diameter shafts and 2 different styles of carrier bearings totaling four different possible carrier bearing set ups
vegaschevy is offline   Reply With Quote
Old 01-24-2010, 09:21 PM   #13
msgross
msgross's Avatar
could depend on tranny option as well since auto's are longer than manuals.
The Garage:
Old 01-24-2010, 09:37 PM   #14
67gmcstepside
Thanks guys, Its tough when you have a frankenstien truck to start with. So far I have a 67 chevy cab with a GMC rad support and 4 headlights on a 67 3/4 gmc frame with 2 piece drv shafts running a 70 350/255 truck motor. 3 sp OTT with a T221 TC.
I apprecate the time helping me try to inderstand what I have.
Old 01-24-2010, 10:10 PM   #15
71 super
71 super's Avatar
My 72 swb is a one piece, brother's lwb 72 is a one piece as well, both are original units for the respective trucks
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 01-24-2010, 11:45 PM   #16
chevroletman223
Dan
chevroletman223's Avatar
my 68 2wd with a th350 and 327 is a 2 piece and its origional
1968 C10 Short Fleet - L79 327, th350
1971 Nova - 327, Th350, 3.73 posi
1971 K10 Short fleet - 350/350
1971 K20 longbox - 350, 4spd
1970 Chevelle, Tunnel ram set up 355, th350
1986 C30 Dually, 454/400
1967 Impala 4 door hardtop, Supernatural clone
1968 Camaro, 327, pwerglide
1967 camaro, numbers match 350, powerglide, bench seat car
1968 Nova, Numbers match 6cyl, powerglide
1968 Nova, 327, th350
1970 Impala, 350, Th350
1968 Impala, Numbers match 350, Th350
1971 Chevelle SS, Numbers match 350, muncie
chevroletman223 is offline   Reply With Quote
Old 01-25-2010, 08:30 AM   #17
eric67m
eric67m's Avatar
1967, k10, 4x4, 327, sm465(4speed), np205(not stock), 2 piece drive line, wide mount carrier bearing on stock mounted crossmember.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 01-25-2010, 09:05 AM   #18
mrein3
mrein3's Avatar
FWIW, my 1971 long wheel base chassis, originally a 3-speed manual on the tree, NP205, had a 1-piece rear drive shaft. I bought a th350/NP205 out of a 1972 blazer and used my truck's original drive shafts. One rear and one front.
I've never dealt with a T221 transfer case. All long wheel base 4x4 I've dealt with had NP205s and a one piece rear drive shaft.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-25-2010, 09:26 AM   #19
67gmcstepside
Thanks guys, I am assuming the 2 piece is original on my 67. I am starting to think 1/2 tons = 2 piece, 3/4 = 1 piece.
My rear only has 2 leafs not 4/5 so I am thinking its a 1/2 LWB hence the 2 piece drv shaft.
Thanks for the replys.
Old 01-25-2010, 10:06 AM   #20
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have never seen a 6 or 8 2wd that came with a factory one piece shaft. I have owned 8 of these trucks ( & burbs).....
Still looking for the 4wd that fits the needs.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-25-2010, 06:26 PM   #21
71 super
71 super's Avatar
As far a 2wd, my bb truck was two piece, changed to one piece, 68 2wd is 2 piece (both are automatics), had 69 swb with 6 was one piece (was 3 spd)
