01-24-2010, 12:47 PM | #1 |
hydrolic clutch issues?
hey guys, my freind has a 86 chevy k10 that had a manual trans swapped in with the hydrolic clutch setup, but when we bleed the lines all the way out the clutch pedal stays at the floor? is there a spacail way to bleed these lines or does this sound like a different issue??
Thanks, Dalton |
01-24-2010, 12:51 PM | #2 |
gets board easy.......
Re: hydrolic clutch issues?
sound like you still have air. Pressure bleed it or put a vacuum pump at bleeder screw. they sell a easy kit most local parts stores.
01-24-2010, 02:07 PM | #3 |
we have trouble bleeding it because the pedal wont return, we have to reach down and pull the pedal back off the floor
01-25-2010, 10:55 PM | #4 |
yeah that happens when you still have air
01-25-2010, 11:21 PM | #5 |
sorry i never messed with hydrolic clutches befor just the mechanical...it ended up beeing the bar that goes to the master cylinder got bent somehow and it was messin everything up. im not sure if they got it bled yet still but i think we got it figured out now lol. sorry for the stupidity.
