Blazer tanks
what year are the blazer tanks people are using, and any links on how toos?
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
Crew Cut
Re: Blazer tanks
mine is a 87 blazer tank. i used it so i could use the in tank elec pump. captkoas can hook you up with everything you need for the swap.
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
Re: Blazer tanks
Thanks so much! That is perfect.
Re: Blazer tanks
Here's Captkaos's how to http://www.captkaoscustoms.com/suicidal.html click on the "how to" on the left.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 01-24-2010 at 06:50 PM. |
Re: Blazer tanks
Looks like the filler neck has been turned alittle?????
Crew Cut
Re: Blazer tanks
good eye! i did turn it a little. just pointed it to my fuel door a little.
Re: Blazer tanks
How low does it hang below the frame?
Re: Blazer tanks
do you any finished pics?
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w ![]() |
Re: Blazer tanks
Here is a link to my build thread and I pretty much followded captkaos' instructions except for a few minor mods...
http://67-72chevytrucks.com/vboard/s...d.php?t=346780 |
I have car A.D.D.
Re: Blazer tanks
Bringing this one back to the top. What size tank are you guys using? It looks like the 31 gallon is the one that was in the 88-91 Blazers. But I am concerned about overall height. The 25 gallon is listed (lmc) at 10.75" tall vs the 31 gallon at 12.75". I know I can get under my truck and do all the measuring in the world. But I also know that just measuring does not truly show where it will sit. My clearance is limited as alot of you know.
I am at the point of deciding if I am going to pursue a Blazer tank and use the stock in tank pump with a regulator. Or just keep the saddle tanks and get a new inline pump. I think the cost will be close either way. I would really rather do the Blazer tank. I just want to be as sure as I can that it will fit.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
GM Addicted
Re: Blazer tanks
still not 1 picture of 1 installed with bed on too see how low it hangs.. hhhuuummm cant believe no1 has one picture
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
I have car A.D.D.
Re: Blazer tanks
TTT for an answer on tank size and maybe some good pics under fully assembled trucks.
#13 |
GM Addicted
Re: Blazer tanks
hahaha the pictures will never come ahahaha
#14 |
I have car A.D.D.
Re: Blazer tanks
I found a 31 gallon. Picking it up this weekend hopefully. I guess we just wait and see what I figure out.
#15 |
been here longer than Liz
Re: Blazer tanks
Gerald, I'm picking up a 31 this weekend. How's yours going?
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
#16 |
Re: Blazer tanks
I PM'd OJOE about it before and he said the tank hangs 6" below his frame. He said his bumper is 14" off the ground and the tank is 11" off the ground.
#17 |
Re: Blazer tanks
Wow, I'm going to have to check tonight then. I don't know if I've got that room to spare.
#18 |
Getting Old; Going Broke
Re: Blazer tanks
I was thinking someone told me the 31 gallon tank would not work on a SWB, had to be the 25 gallon. The 31 gallon tank hanging underneath my suburban comes down 7.5" below the bottom of the frame, if that helps at all in your measuring. There is a void between the tank and the floor, but it is not but maybe 1/2" really.
#19 | |
Re: Blazer tanks
#20 |
Re: Blazer tanks
That's what I meant. Yeah, that's it.
Ok, measured mine finally, it's a 31 gallon with a skid shield. I'm also guessing the 89 year will have the fuel pump in the tank like the trucks? That would make it easier for a LS type engine swap? Last edited by RandyP; 07-02-2010 at 02:03 PM. |
#21 |
Re: Blazer tanks
Well hell, there's a 40g that doesn't fit??? I learn too much after the fact.
#22 |
Re: Blazer tanks
You could make it fit, just could not have a rear bumper probably.
![]() Low87, I'd go out on a limb here and say the only way a burb would have a 40 gallon tank would be special order, or a 3/4 ton 454 engine model. Last edited by RandyP; 07-02-2010 at 02:06 PM. |
#23 |
Re: Blazer tanks
I don't have a rear bumper....only a pan. I get what you're saying though. I'm just concerned about the possibility of this '91 Burb having a 40 since it's a conversion. We'll see. BTW Randy, I don't have to figure out how to pull the tank, he did it for me.
#24 | |
Re: Blazer tanks
dunno if it was special order.
#25 |
Re: Blazer tanks
You're not helping Joe.
