New here need some help w/ ls swap
I'm wanting to do a ls swap on my 85 swb gmc if i could get a list of parts needed and also where can i get the plate for the motor mounts .thx for looking
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: New here need some help w/ ls swap
I got my motor mount plates off ebay for $30. The list of parts will depend on what donor you find and what you are trying to do with the truck. There is a search function that works great on this site(not so much on others) and look in the projects and build section. I think theres about 8 of us doing this swap right now and a couple show offs cough, Bob, cough
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
im trying to do a 6.0 4l60 swap ive been trying to look for the harness do you know how much the nelson performance harness is
Next project: 1970 K10
Hey now!!!!
![]() Check my build thread, starting at page 18. Somewhere along the way there is a template that you can build your own adapters. Car Shop Inc sells them http://carshop.carshopinc.com/produc.../86959/C/S2349, but they can usually be found cheaper on eBay like Josh did. If you have the time I did list a bunch of part numbers, but I'm working on making a master list of part numbers for the different areas like fuel system, electrical, etc. Do you not have a harness? I don't know what Nelson charges for any of his stuff. I have seen complete untouched harnesses on eBay too for a $100-$200, and even reworked harnesses. If you can find an unmolestered harness at a reasonable price, Jesse at wait4meperformance.com will rework the harness and reflash the PCM for $360 including rturn shipping. Here is a factory one for $150. http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 01-24-2010 at 03:49 PM. |
here is what i did!!!
header from summit part# SUM-G908 $153.93 they are shorty headers fit 99-04 truck requires slight mods to PASS side rail , i welded round stock to the underneath of the rail where i modifed it -you can use stock manifolds if you wish but make sure there the non EGR TYPE they will hit the frame where the EGR pipe mounts to on the manifold the header claim 15hp but do sound great trans-dapt 4572 engine mount adapters $47 seems to put the engine nicely against the firewall with plenty of clearance, they're from summit as well fuel pump airtex fuel pump E3270 provides plently of PSI $79.99 AutoZone fuel pump lines, people spend money here for no reason go to a junk yard and get lines from a pickup or tahoe 99 -2003 from the rail to the tank and only modify the part where it goes into the tank use a 87 - 91 EFI sending unit make sure you use the EVAP lines if your using the charcoal canister ! im not so i got rid of it and plugged the hole in the intake but tapping it out with 1/2 tap and use a short bolt! oh if you remove the EGR stuff of a 99-02 engine just remove the the plate that screws to the intake from the flex steel pipe and cap it dont buy one from GM for $30 takes 10 min to mod top rad hose of a 2001 silverado $17.99 temp switch adapter 1/4 3/8 1/2 about $18.00 S&P harness mods $212 including the OB11 i used a guy from ebay i was a little worried but it works great oh by the way i dont have A/C but others do i have his email so message me if you want it ECU mods removing egr , rear O2s ,removing VATS, etc etc etc $75 i have his email too its a different guy there are a few other mods like i moved the battery to the drivers side make a better fit IMO use a diesel tray there cheap , i used a KN filter out of a 2001 truck i got it for $75 used made a brackets works nice!!! if your running cats your gonna have to make some mods to the factory 99-04 Y-pipe OR if your not running them you can do what i did i made my own flanges and made the pipe extentions from each header i put the front O2 bungs in each pipe extention and i was good to go!!! i cut my own gaskets from exhaust gasket sheet with the aluminuim works great no leaks you might have to move your trans crossmember back and mod your drive shaft i cut mine 1 3/4in cost was $55 im using a 91 blazer/burb speedometer takes care of the the 4l60e /4l80e electronic speedo ive posted this link before but if you havent seen it here it is again
78 C-10 5.3 LSX -4L60E |
I used the carshpinc plates, here is something new I found on ls1truck.com:
http://dirtydingo.com/store/product_...oducts_id=1308
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
