I poop on Ford!
Some of you may or may not be into street/track racing. However, just because you're not using these tires now doesn't mean you might not want to in the future. Speak up and help the rest of us how currently use these products while enjoying our hobby.
There is legislation pending that could either make DOT approved racing tires illegal, or just make them so expensive that they will be unaffordable to most or the manufacturers will simply stop making them. The whole Firestone/Ford thing has caused this. If you feel as strongly as I do about this, then please follow the instructions contained in the link provided and let them know how you feel. Remember, government isn't necessarily a bad thing when taken in moderation. Check out: http://www.hoosiertire.com/fmvsshlp.HTM Please feel free to pass this around to any other boards/lists you are a member of. ------------------ 1972 Chevy Blazer 2WD - 400 SBC, bored, ported/polished heads, 9.5:1 dished pistons, Lunati 480/292 cam, electronic ignition, Edlebrock Performer intake, tricked out Rochester 850CFM Quadrajet, long tube headers, Flowmaster 40's, TH350-C with lock-up switch, 2800 rpm stall, shift kit, custom driveshaft, stock GM 12- bolt rear with Auburn Pro Series limited slip 3.73's, 2" drop spindles, 2" drop rear coils, track bar kit, front/rear stabilizers. 1999 30th Anniversary Trans-Am Coupe #1494 - M6, Flow-tech cut-out, Flowmaster, free mods. One of 292 coupes with M6 and in-dash CD.
1972 Chevy Cheyenne - LWB, factory 402BB 2005 Chevy Suburban LT 2006 Chrysler 300C - SRT8 |
| Bookmarks |
