Old 01-24-2010, 09:17 PM   #1
Normy71
Front End Parts/Install
I'm in the process of putting my front end back together on my 71 GMC and It's been a while since I took it all a part. I am looking for info on upper& lower Control arm shafts. How tight do I make them? Do they need to be tack welded in place? Any one have the torque specs for this and the rest of the front end bolts and related items?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 01-24-2010, 10:56 PM   #2
Normy71
Re: Front End Parts/Install
I found this http://www.chuckschevytruckpages.com...que_specs.html
not sure if this is for my truck?
But upper Control Arm shaft 70lbs
lower Control Arm shaft 115lbs
is this what I should use
Old 01-25-2010, 12:15 PM   #3
Normy71
Anyone have a link to a build or any kind of help?
Could not find anything,,
Old 01-25-2010, 01:28 PM   #4
spr85gmc
spr85gmc's Avatar
Just did this on my66. I didn't know a arms needed to be torqued to specs so count me in on the need to know...
spr85gmc is offline   Reply With Quote
Old 01-25-2010, 01:53 PM   #5
dfwright
dfwright's Avatar
I have the 1972 Chevrolet Overhaul Service Manual for Cars & Light Duty Trucks book, which specifies 95 foot-lbs for the upper control arm bushings, and 130ft-lbs for the lower. I don't know if it is different for different years or not. I also don't know if GMC is different than Chevy.
If you can find a copy of the 1971 version of this book, it also lists all the torque specs for most of the parts.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-26-2010, 02:01 PM   #6
Normy71
I have heard of people tack welding these not sure if it is required?
Old 01-31-2010, 02:21 AM   #7
Heater63
Heater63's Avatar
I've never heard of a need to tack weld them.
Did you guys replace your shafts or the nuts/bushings? or just replace the seals?
I am cleaning up my shafts and nuts on my 63, about ready to reassemble, and they look fine for re-use to me, but thats just using eyeball inspection. Should the shafts and nuts be replaced with new?
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-31-2010, 09:40 PM   #8
Normy71
I just put in all new because I had everything apart.
After 40 years who knows what you have.
My 2 cents.
Old 01-31-2010, 09:51 PM   #9
Normy71
Any one have this problem?
My top Arm is rubbing on my drop spindle? It is a 2 1/2" drop from CPP
( CSP4S ) not sure if I have a upper ball joint problems or my new drop spindle need some grinder work? Also my angle on my outer tie rod seems quite steep?
any Input?
Old 01-31-2010, 10:43 PM   #10
texastrendz
do you have weight of the truck on it, no jacks or jackstands that is
texastrendz is offline   Reply With Quote
Old 01-31-2010, 11:02 PM   #11
mullit
mullit's Avatar
X2 and the rest of the truck
mullit is offline   Reply With Quote
Old 01-31-2010, 11:16 PM   #12
Heater63
Heater63's Avatar
thats Normal Normy: you don't have your rubber bumpers in and you don't have any weight on it. Unless your going airborne with some radical driving, it will never be an issue, even without bumpers.
292 + TKO500
Old 02-01-2010, 10:25 AM   #13
Normy71
The engine weight is on the frame in picture 2 and 3 but just the 5.3 engine (aluminium ) not sure how many pounds it is?
Old 02-01-2010, 11:29 AM   #14
suville
suville's Avatar
Once you "load" the suspension all that will change, like stated in the previous post unless you get it airborne you will never be at that extreme angle.
suville is offline   Reply With Quote
Old 02-01-2010, 11:41 AM   #15
Normy71
I should have said the weight is on the front wheels not the FRAME! but just the weight of the 5.3 only, is how it is sitting in picture 2&3
