Old 01-24-2010, 10:19 PM   #1
rlb67
Nova 3 speed
I have found a synchronized 3 speed Muncie transmission out of a 71 Nova, 307 floor shift. Will this transmission work in my 67 truck with column shift without a whole lot of problems? Transmission comes with yoke. Truck is 250 6 cyl.
Thanks,
Randy
Randy, West TN
67 Fleetside SWB L6 3 speed on column
84 Feetside SWB L6 3 speed on column
yes, I like column shifts
99 Dodge 4X4 Ext. Cab
rlb67 is offline   Reply With Quote
Old 01-25-2010, 07:16 PM   #2
rlb67
Re: Nova 3 speed
Anyone have any idea?
Randy, West TN
Old 01-25-2010, 09:26 PM   #3
69 longhorn
Re: Nova 3 speed
Your 67 probably has the old no syncro (2 pin Muncie). the saginaw ,with floor shifter will bolt right in(you need to nut & bolt the bottom 2 holes on the bell), as the truck trans had the bottom ears on the trans threaded. Other than that chop a hole in the floor for the shifter, swap the slipyolk, & most likely cut & rebalance the shaft. Some of the old muncie trans had a short tailshaft. Best of luck,crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-25-2010, 11:44 PM   #4
rlb67
Re: Nova 3 speed
Thanks for the info.
Randy, West TN
Old 01-26-2010, 09:54 PM   #5
mike16
Re: Nova 3 speed
the lower ears on truck transmissions are threaded and bolts fasten from inside the bell housing. car transmissions the lower ears are not threaded and fastners go through the ears and thread into the bell housing
mike16 is offline   Reply With Quote
