Old 01-24-2010, 10:40 PM   #1
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Kick Panel Rust...
My kick panels have some rust towards the bottom where it meets the floor (luckily, my only rust spot)..Ideas for fix? Maybe find a donor kick panel?
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 01-24-2010, 10:42 PM   #2
hayhauler71
hayhauler71's Avatar
Re: Kick Panel Rust...
Do you have some pics of the rusted area?
hayhauler71 is offline   Reply With Quote
Old 01-24-2010, 10:46 PM   #3
COACHMEASON
Keep On Keepin' On
No...its in a shop about 15 miles away..I will try to get one later this week...Its probably an inch tall 2 inches wide...
07 Avalanche Z71
Old 01-24-2010, 10:52 PM   #4
powell72
powell72's Avatar
The aftermarket makes a repair panel for that, I think it's around $15.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-25-2010, 12:09 AM   #5
leh72super1500
GMC with Blue Plaid
leh72super1500's Avatar
My kick panels have the same, but its only about an inch up from the floor, fortunately it is all still solid with no holes. My plans are just to clean it up with a wire wheel, treat with rust mort and then smooth off with plastic filler and then paint.
Current:
1972 GMC Super Custom 1500 402 < 73K Orig MI
2015 GMC Canyon SLT(Daily Driver)
Previous:
2008 Chevrolet Colorado LT 2.9L I4
1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI
1984 GMC S-15 2.8L V6
1976 GMC Sierra Classic 2500 Camper Special 350
1980 GMC High Sierra 3500 Dually 350 4spd
1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it)
1969 GMC 910 250 I6 4spd
leh72super1500 is offline   Reply With Quote
Old 01-25-2010, 12:43 AM   #6
Dynomutt
Dynomutt's Avatar
Not sure I'd say "lucky" it's the only rust spot. That's a pretty complicated area. There are patch panels made for it and if the rust is high enough above the floor it could be a pretty easy repair. If it's rusted down to the floor it could be a lot tougher. That panel pinches between the floor and the A pillar and, it's right where the front cab support ties in. You may end up cutting out a piece of the floor, even if it's good metal, and you may have an issue or two with the cab support in order to get all of the rust out of the kick panel and make the repair properly. Still shouldn't be a real bad repair but could be a lot more work than it appears to be.
I think I was lucky because everything around mine was rusted out so it made that panel easier to get to and repair.
Good luck with it.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 01-25-2010, 07:48 PM   #7
powell72
powell72's Avatar
Good luck with it.
This is exactly right, and mine was the same way, everything I removed to get there was rusty also!
Chris
Old 01-25-2010, 08:20 PM   #8
mbgmike
Good luck with it.
We have done many,many of these trucks through the years.In fact there is not one panel that I have never worked on.
You are correct. This can be a tough area. I don't ever recall one however that rusted through just above the floor. Rust has shown up in some areas that are unusual but here I can pretty much say its at the floor. It is a water trap. Their is no easy fix to do it correct. None. Usually they can be replaced when doing the rockers and the pillar. Thats normal.
If the pillars are fine and the rockers are to, the only way to get to it is to cut a section of the floor to get access to the bottom of the kick plate. Then weld the section back in. If you have the skill its a part that you can make with limited tools and skill. You may want to make the replacement panel go up a little higher than the rusted area for ease of welding and saving your back. I lay on my stomach all the way across the cab. I can't twist around and weld anymore.
mbgmike is offline   Reply With Quote
Old 01-25-2010, 09:42 PM   #9
Hart_Rod
Hart_Rod's Avatar
What they said...... I had to make the same repair you are talking about. If you look at my burb build thread, I show some decent step by step pictures of the process described above.
Hart_Rod is offline   Reply With Quote
Old 01-26-2010, 12:26 AM   #10
COACHMEASON
Keep On Keepin' On
Thanks...
07 Avalanche Z71
Old 01-26-2010, 08:42 AM   #11
mrein3
mrein3's Avatar
It is a water trap AND back in 1967 - 1972 you didn't have a galvanized sheet metal that was then dipped in epoxy primer like you have in today's modern assembly facilities.
The back side of EVERY panel on our trucks that didn't get overspray, and isn't in the desert southwest is rusty. It is only a matter of time before you see it come bubbling around or through. Up here in the rust belt it is only accelerated by the application of salt spray six months out of the year. This is why ALL rockers eventually rust out. There isn't any paint on the back side of them! What happens to sheet metal that isn't painted after 40 years? Yup. Rust.
I recently drilled out all the spot welds on a bed side and separated the inner from the outer because I sould see surface rust in there. Not for the faint of heart. I'm afraid you desert guys would faint if you saw what I saw in there.
That kick panel area is a common rust out area in the rust belt. When you walk across the street in your boots, all that slush and snow you pick up is full of salt from the road. You get in and it all falls on the floor and melts from the heater. All that salt water runs into that seam.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
