People know me
body mount bushings
So anyone have a source for a cheap set?
This will be a daily driver so anyone have actual real life opinion on these? I have never owned a rig with poly bushings before. I have heard they squeek, ride rough etc, and I have also heard they are the best thing ever.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Grandpa in the rustmobile...
Re: body mount bushings
free bump which bushing should you go with?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I have poly bushings on my longhorn, & will say that they are a little harsher,but no issue with squeaks. If you do any 4 wheelin, you may want to stick with rubber ,as they flex a bit & may help not to rip up your tin. crazyAL
http://community.webshots.com/user/hotrodhorn |
Got my poly mounts from brothers. I have poly motor mounts too. If i had to do it all over again, i'd probably go with rubber cab/radiator support mounts. I have a mildly built small block, somewhere between 320 and 350 hp. Whole truck vibrates at idle, i feel every bump in the road, and i have about the same amount of rattles as when was stock. I blame the poly bushings at least partially for all of that. But hey, supposedly i'll never have to change them.
whats diff. between rubber poly and rubber why go rubber vs poly or vica versa, does poly last longer or what?
![]() Join Date: Feb 2001
Here are some past posts that might be of interest...
http://67-72chevytrucks.com/vboard/s...d.php?t=374367 http://67-72chevytrucks.com/vboard/s...d.php?t=192342 http://67-72chevytrucks.com/vboard/s....php?p=3701630
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#7 | |
double post,please remove. Thanks,crazyAL
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 01-25-2010 at 12:13 PM. Reason: remove, due to double posting |
