Old 01-25-2010, 02:09 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
Carrier Bearing
I believe that my carrier bearing is bad (i can wiggle the drive shaft around in it). where can i pick one of these up at? Autozone/Advance show a different type of mount than i have. the ones they show mount on either side but mine has two bolts in the centre. what is the difference in these two types? and how do you go about changing this?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-25-2010, 02:13 PM   #2
vegaschevy
Re: Carrier Bearing
Just as you said, they mount either in a line or on either side.
you have two different sizes of shafts, 1.3 or 1.8 i believe. Any auto parts store will sell them
vegaschevy is offline   Reply With Quote
Old 01-25-2010, 02:33 PM   #3
hayhauler71
hayhauler71's Avatar
Re: Carrier Bearing
http://www.iedls.com/bearings.html Take a look here if you want something that will last.
hayhauler71 is offline   Reply With Quote
Old 01-25-2010, 04:01 PM   #4
chevroletman223
Dan
chevroletman223's Avatar
Re: Carrier Bearing
you can get them from classicparts.com you can get either style and theyre cheap too. only $17 i think
1968 C10 Short Fleet - L79 327, th350
1971 Nova - 327, Th350, 3.73 posi
1971 K10 Short fleet - 350/350
1971 K20 longbox - 350, 4spd
1970 Chevelle, Tunnel ram set up 355, th350
1986 C30 Dually, 454/400
1967 Impala 4 door hardtop, Supernatural clone
1968 Camaro, 327, pwerglide
1967 camaro, numbers match 350, powerglide, bench seat car
1968 Nova, Numbers match 6cyl, powerglide
1968 Nova, 327, th350
1970 Impala, 350, Th350
1968 Impala, Numbers match 350, Th350
1971 Chevelle SS, Numbers match 350, muncie
chevroletman223 is offline   Reply With Quote
Old 01-25-2010, 04:43 PM   #5
kevmic28
kevmic28's Avatar
Re: Carrier Bearing
Napa Carries them. Advanced auto does not have the correct one. I just replaced mine last week. there is a good thread on this that I found last week.
Here it is.
http://67-72chevytrucks.com/vboard/s...d.php?t=342736
Might as well replace the u joint since you are going to have to remove it anyways.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 01-26-2010, 10:11 PM   #6
mike16
Re: Carrier Bearing
the difference is because some are coil spring rear ends and some are leaf spring rears. when you remove the drive shaft and separate the two shafts you will need to take an open end wrench and grind it to be much thinner to get in between the drive shaft and the u joint.
also when the assembly comes apart you will or should have two dust shields. one on either side of that bearing. they are also important because they help keep the bearing inside the rubber cushion surrounding it. If they are not there, the movement of the drive shaft forward and backward may push the bearing out of the rubber cushion. this is more likely to occure in colder northern climates when the rubber becomes very stiff and inflexable.
mike16 is offline   Reply With Quote
