01-25-2010, 03:46 PM | #1 |
kick panel install
Hey guys, I ordered a set of kick panels that you can put speakers in and didn't realize there was so much modifying to be done. I realize that I will need to drill holes for the lever to open the vent on one side and the vaccum canister for the other, but I didn't realize I would have to cut off most of the back section on the passenger side because of the contour of the cab. Has anyone else had to do this or did I get the wrong panels?
01-25-2010, 07:36 PM | #2 |
Re: kick panel install
Did you check these out?
I wish he had these before I bought the only ones I could find... that's my truck with the smooth cowl I got from Tony by the way http://67-72chevytrucks.com/vboard/s....php?p=3747440 Last edited by Mondo; 01-25-2010 at 07:40 PM. |
01-25-2010, 07:45 PM | #3 |
Moderator
I had to trim mine in the manner you described. I used a dremel tool....no biggie.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-28-2010, 04:37 PM | #4 |
How are they held in place on the kick panel of the trk? it says the weather stripping holds them but that is hard to believe.
01-30-2010, 04:39 PM | #5 |
I put 6 by 9 speakers in my 69 truck doors. I did not know if the kickpanel speakers would hit the emergency brake pedal or not. Don't put speakers under the seat. They sound terrible.
01-31-2010, 04:59 AM | #6 |
Moderator
I used 3M double sided tape. Worked perfect.
