01-25-2010, 05:17 PM | #1 |
engine swap
Hello, I'm sure that this has been asked a million times but where do I find information on a engine swap I want to install a 350/350 trans in a 52 chevy pick up I belive in had a 6 in it, any help would be great Thanks Jeff
01-25-2010, 07:27 PM | #2 |
Re: engine swap
I can take pictures of mine for you if you are interested.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis Support our troops, stand behind 'em or get in front of 'em. What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance? |
01-25-2010, 08:09 PM | #3 |
Re: engine swap
Pictures would be great pls em to cal2indy@comcast.net Thanks again Jeff
01-25-2010, 09:35 PM | #4 |
Re: engine swap
Email sent. They aren't the greatest pics but I don't have as much room as I thought to get in there. I will be pulling the front end down in the next few weeks so I can give you precise measurements if you want. They have been working for 19 years so....
01-25-2010, 09:43 PM | #5 |
Re: engine swap
There are a lot of ways to do it but if you are keeping the stock I beam front axle probably the simple way is to buy the engine swap crossmembers for both the engine and the transmission from a vendor. Those pretty well make it a set it where you want it and bolt/weld it up thing.
If you cut the crossmember out that normally goes under and holds the bellhousing on the six you should figure out how to brace the frame when you have everything in place as the rails will twist outward over time due to the weight of the cab pushing down on the ends of the brackets for the cab mounts. That is why you see a lot of modified AD trucks that look slightly bent in the middle where the nose meets the cowl. |
01-25-2010, 09:46 PM | #6 |
Re: engine swap
I'm so tight I squeak when I walk so mine were homemade and the aftermarket world was kind of slim in 1990. They are made out of 2x2 tubing and welded to the frame.
