Old 01-25-2010, 09:01 PM   #1
doublearrow
help identifying part
I was replacing the PCV valve earlier and I found a broken vacuum line. I'm not sure if i broke it in the process or if it was already that way. It runs right next to the vacuum line for the pcv valve into the base of the throttle body and plugs into a black box that is mounted on the same bracket as the manifold absolute pressure sensor. I've gone through my haynes trying to figure out what it is, but the best I can do is the picture of the pcv valve on page 6-19. It shows a picture of the line that is broke.
Two questions what is the part it plugs into? and where can I get a new line? I've tried searching the part number 14102070 and can't get anything to match. I appreciate any help.
Here's a picture of what it plugs into. The pen is pointing to the box it plugs into.
THe second picture shows the port it plugs into next the pcv valve on the base of the throttle body (pen is not pointing to it)
doublearrow is offline   Reply With Quote
Old 01-25-2010, 10:45 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow Re: help identifying part
It's been a while but i think it's the EGR VLV silnoid it needs to be connected to the vaccum port on the lower rt front of the TBI base the one thats open in that pic.
You will have to go to a u-pick it junk yard and get one if you cant find one from a truck just get a section of that abs plastic hose with some bends in it that look close and the rubber tips and make it.
Or just use some regular rubber vaccum hose.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-25-2010, 10:56 PM   #3
jake wells
why not a section of regular vacuum line just to try it
jake wells is offline   Reply With Quote
Old 01-26-2010, 11:53 PM   #4
doublearrow
I'll try a regular piece of vacuum line, I didn't know if size mattered. The old line has big fittings, but a very small line. Thanks for the help.
