Fleetside Rear Coss Sill
Is the rear cross sill on the fleetside welded to the bedsides? Having a hell of a time getting it off!
Where did THAT bolt go?
Re: Fleetside Rear Coss Sill
I believe they not only bolted them together, but spot welded them too.
I had a terrible time getting mine apart! Good luck.
The Swiss Car Club......A drinking club with a car problem.... |
Zero Albedo
Mine was on my 66 GMC- it was a bear to get it loose without a lot of damage.
Baz "Deserve's got nothin' to do with it." 66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467 65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432 65 Chevy Panel (former U.S.Navy truck) 64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348 64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now) 68 Dodge Charger |
They are attached to the bed side on each end with two bolts/weld nuts, you can look up underneath, to see them and from the factory there are two stitch-welds on both ends...one horizontal weld on the top flange of the rear cross sill-to-rear bed pocket and one vertical weld on the face of the rear cross sill-to-rear bed pocket. These are easily removed with a 4" Zip wheel/cutting wheel, without damaging the cross sill or the bed side bed pocket.
This has been posted before and I thought I had some photos, but I am not able to recover them. Perhaps, someone else will have them available to post. Last edited by LILRED66; 01-26-2010 at 10:09 AM. |
no need for pictures... I see exsactly what you're talking about. Thanks guys, much appreciated.
1961 crewcab
should actually be 4 bolts on each side right? along with the stitch welds.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
