Old 01-25-2010, 11:59 PM   #1
tap500
Door Gap
I need some info about the door gaps. The aft end of both of my doors is too large after doing all the metal work on the lower section of the cab (lower f/r pillars, outer floors, cab corners, kick panels) I have waited to put the rockers in until I got some good doors. With the doors on the aft door gap is too large.
How do I adjust the rear door gap, with shims behind the hinges?
tap500 is offline   Reply With Quote
Old 01-26-2010, 07:29 AM   #2
Bruce88
Bruce88's Avatar
Re: Door Gap
On my drivers side I used shims behind the hinges to get the door gap I wanted.
You can see the shims I made on my build thread (post #195) http://67-72chevytrucks.com/vboard/s...=318544&page=8
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
