Old 01-28-2003, 09:43 PM   #1
case_bt
case_bt's Avatar
how do you remove rear axles
I'm in the process of switching to 5 lug
I want to know how to remove the axles
I'm working on the drivers side right now
I pulled the c ring off what do I do now?
case_bt is offline   Reply With Quote
Old 01-28-2003, 09:51 PM   #2
Ratpowerd67
take the wheel and brake drum off and slide it out. be sure not to cut the axle seals unless you intend to replace them, now is the time if you plan on doing this........good luck
Ratpowerd67 is offline   Reply With Quote
Old 01-28-2003, 10:22 PM   #3
case_bt
case_bt's Avatar
I just searched for axle topics I just did the wrong thing but thanks to 71BBK10
and his pics I figured it out
http://67-72chevytrucks.com/vboard/s...threadid=23462
Old 01-28-2003, 11:50 PM   #4
case_bt
case_bt's Avatar
one more ? how much fluid does it hold
