3/4 body on 1/2 frame and running?
will a 3/4ton body fit right onto a 1/2ton truck?
if not,what mods need to be done?
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
Re: 3/4 body on 1/2 frame and running?
Yes the bodies are the same. the 3/4 has thicker body bushings but the dimension change is in the frame not the body. If you are using the 1/2t frame use 1/2t body bushings
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
my idea was to put the nice body off the 3/4 i have that has no motor on my 1/2 that im putting a built small block in,and doing those spring spacers like 2" of lift and running 31's or so(its a longbed).
i just thought it would be neat and different.
