Need a Measurement
O.K. guys.
I need to know how far up the brake pedal sits from the hole in the floor where it comes through. This is on a 57 with the stock pedal. I have to make a tube to conect my pedal to my booster which I mounted behind the cab. Thanks a lot. Kim |
Re: Need a Measurement
It may not be the same between trucks. My cab may sit higher on the frame than yours or the lever may be offset in another direction. After I mounted my cab I had to cut the pedal and reweld it to the hight and arc I wanted it to travel.
#3 | |
I could compare yours to some others and get an average. Kim |
Here is a photo that shows the stock pedel location. I used the stock pedel and made my own under frame setup. You can see that the stock location is farther to the right and lower than jjjmm56 aftermarket one.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
You might want to think about mounting some type of sleeve with nylon bushings for your rod to ride in. That looks like a good distance to the master. And about pedal hight I'll thake measurments tomorrow but maybe wait to adjust it till the cab is on and seat is in. But keep up the good work,I always enjoy seeing other peoples progress
Mine is 6 1/2 from floor to center of pedal and 1 3/4 over from stock floor location
Kim, I have a 55 and 57. The 55 I did the upgrade to PB and mtd the bracket under the cab. I still ended up cutting 3" out of the pedal.
If you would like a measurement of the 57 pedal in the stock location I can get that too. It's still untouched.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
#8 | ||
Kim |
