landarts
![]() Join Date: May 2005
Need Help with motor mounts (again)
This is getting a little confusing to say the least. Below you will see what I have to put a Chevy 6 cylinder 250 motor into the 67 Chicken Dinner truck. The truck originally had a 327 v8 that had a blown rod when I bought it. For know I have a 6 cylinder 250 motor that I would like to put into the truck while I take my time getting the 327 rebuilt the way I want it. I have done all kinds of searching for this particular part on the internet, this site and at the local parts stores. I have not been able to turn anything up. Any advise where I might look, or even what the part is called would be helpful.
thanks for any help, Jim |
landarts
Re: Need Help with motor mounts (again)
I am trying to identify the part in the last picture that is circled.
Champagne Taste on Beer Budget
Looks like the drivers side motor mount and tower assembly.
Coming Soon: Project 1970 Country Truck |
![]() Join Date: Mar 2003
The part that came on your engine on the pass side is for a later model mount
landarts
Yes the mount that is on my engine is from 1979 - Does anyone know where I can get the right mount online?
yea, thos motor mounts attached to your block are for a latter vehicle.
landarts
Hey everyone I know that the metal brackets that are on the truck are from a later model. I was looking to see if anyone knows what the right metal mount on the motor looks like or where I can try to get some .
I think the right one is the same its hard to tell in the pic http://67-72chevytrucks.com/vboard/s...d.php?t=382199 and I can't remember for sure, but I will look tomorrow and I will see if I have another set. James
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ Last edited by fishingjred73; 01-26-2010 at 10:36 PM. |
landarts
That would be great fishingred73 and if you dont do you know where I might look or what is actually called so I can search for it on the internet....Jim
It looks to me like you have all the parts you need. Those new moter mounts bolt the block where that late model bracket is and then to the engine tower. Maybe i missed your question but i have a small block with I6 mounts and towers if you need a picture.
Dan
![]() Join Date: Dec 2009
what he needs is the spacer plate that goes between the mount and the block.. it was on all 250s and 230s in these trucks to expand the mount outward so that the 6cyl would reach to the frame towers.. i dont have a picture of it or know where you might find one other than a parts truck, or ebay, or maybe here if people understand what your looking for. Hope this helps your search. Dan
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
So I am going from a 292 to a 350 do I need to change the I6 stands or just move them??? sorry to hijack this thread
#13 |
Dan
tlandmark, the 292 stands are different than the the others. You can put a small block on any i6 mounts except the 292 because one of the mounts is more forward than the other side. So you will have to switch out your towers. I think member seacrow had a set of towers that he was selling, he may still have them. Hope this helps, Dan.
#14 |
landarts
I am sorry for my poor communication. The part I need is metal and it bolts directly to the block (see pict 1 below). The next part is the metal and rubber bushing- which I have (see pict 2 below). Then the motor tower that mounts to the frame- which I have and it is the inline 6 version (also see pict 2 below)
So the part that is in picture 1 is what I am trying to find out what it is called so I can search for the part on the internet, or where I might be able to find a set . To answer someone else post above about the inline 6 towers working on a v8. I have heard yes and no to that. What I know is that the v8 towers are smaller than the inline 6 towers as the pict from texasfirefighter shows (see pict 3 below). |
#15 |
Sorry, no dice on the second set, their car mounts. But here is a better picture of the right side mount and it is different from the left. (I don't know exactly what to tell you to call them?) You should post a WTB in the classified section on here if you haven't already.
'68 250 6cyl right side engine block mount ![]() The picture you have in post #14 is the left side.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ Last edited by fishingjred73; 01-27-2010 at 01:27 PM. Reason: added |
#16 |
landarts
O.K. thanks for the picture that should help. I will try to post something later today in the WTB section.
#17 |
Is this what you need.
#18 |
landarts
That looks like that could be the ones I need. I will check to see if that is the setup and I will pm you back. thanks
#19 |
Looks like you have a winner!
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#20 |
landarts
Just wanted to say thanks to all that helped out sourcing the right mounts.
Jim |
