01-26-2010, 09:36 PM | #1 |
Rear end swap
Will a 93 Chevy 1/2 ton rear end fit in a 72 C10, has anyone here done such a swap?
Thanks, Steven |
01-26-2010, 09:42 PM | #2 |
Re: Rear end swap
No, not unless you cut the spring pads off and move them , The yoke is diffrent you can get a conversion u joint at NAPA. why not just get a 12 bolt 5 lug 72 rear ? stronger & direct bolt in ....
01-26-2010, 11:15 PM | #3 |
its all about the +6 inches
Re: Rear end swap
does the 72 have coils or leaf springs?
01-27-2010, 07:47 PM | #4 |
Re: Rear end swap
It has coils.
01-27-2010, 10:11 PM | #5 |
Re: Rear end swap
I went with a Ford nine inch out of a 78 F-150 3:55 posi $150 at the local junkyard cut the perches off the old rear and welded them onto the new rear. Glad I did!
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!! |
