Old 01-26-2010, 09:48 PM   #1
WHAMMY'DWONDER
C30 cab on c10?
Hey guys, quick question, a c30 cab fit on a c10 chassis? Im getting a BBW, A/C cab with minimal to no rust, and just want to make sure it will fit alright.Thanks!
WHAMMY'DWONDER is offline   Reply With Quote
Old 01-26-2010, 10:48 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: C30 cab on c10?
It will bolt right on... remember that 60-62, and 63-66 use different front mounts, and require some fab work to interchange.
Old 01-27-2010, 12:23 AM   #3
Captainfab
60-66 Nut
Re: C30 cab on c10?
What Jon said.....
Old 01-27-2010, 01:08 AM   #4
WHAMMY'DWONDER
Re: C30 cab on c10?
Cool, both are 66' cabs so shouldnt be a problem. thanks guys!
Old 01-27-2010, 10:11 PM   #5
LILRED66
LILRED66's Avatar
Re: C30 cab on c10?
The rear cab mounts on the C20 & C30 cabs are different than the C10 rear cab mounts, but that is easily addressed.
LILRED66 is offline   Reply With Quote
Old 01-27-2010, 10:21 PM   #6
WHAMMY'DWONDER
Re: C30 cab on c10?
LIL RED, do i need to change the mounts on the frame then to accomidate the c30 cab? or do the c10 ones work?
Old 01-27-2010, 10:37 PM   #7
LILRED66
LILRED66's Avatar
Re: C30 cab on c10?
The photo shows the factory C20 & C30 rear cab mounts, which are actually factory riveted to the frame, so you can use the C30 cab on your C10, by utilizing the C10 rear cab mount perches, which are also factory riveted to the frame. You will need a new rear cab mount kit. They are available in polyurethane or rubber compound. You can purchase them here:
www.lmctruck.com
www.classicparts.com
www.bowtiebits.com
www.oldchevytrucks.com
www.truckandcarshop.com
If you need any help, send me a PM or give me a call and I will help you, otherwise good luck and let us know how things work out.
Old 01-27-2010, 10:40 PM   #8
rookierodbuilder
rookierodbuilder's Avatar
Re: C30 cab on c10?
I really don't think the rear cab mounts will have to be changed. I've got a c-30 parts truck myself and have noticed the different cab mounts as well. As far as I can tell, the way the 2 mounts attach to the cab and frame are identical. the only difference is the c-30 cab mounts have rubber sandwiched between the part that mounts to the frame and the part that mounts to the cab. I'm sure this was in an effort to keep the c-30 trucks from beating the driver and passengers to death due to the massive spring packs in the back of the ton trucks.
rookierodbuilder is offline   Reply With Quote
Old 01-27-2010, 10:51 PM   #9
jonzcustomshop
1961 crewcab
Re: C30 cab on c10?
you just need to reuse your c/10 rubber bushing for the rear mount.
Old 01-27-2010, 11:32 PM   #10
LILRED66
LILRED66's Avatar
Re: C30 cab on c10?
Reusing rear cab mount rubbers is usually not possible, since they have been flatten over the past 40+ years, so I think you should install new ones, while the process is easy and it helps to maintain the correct height of the body lines of the cab with the bed.
Old 01-28-2010, 09:12 AM   #11
jonzcustomshop
1961 crewcab
Re: C30 cab on c10?
thats probably what i am chasing on my 61....
