Old 01-26-2010, 10:15 PM   #1
Baged72
Baged72's Avatar
How do I install headlights??
Ok i have no clue how to install my front head lights, i have the bezel mounted to the grill and i have the headlight retainers where do those screw into to? My radiator support has no screw holes and only 2 holes that are square cut. Am i missing a bracket?? 2nd.. do the bezels go in last?? pictures or a link much appreciated, thanks!
1972 chevy front end, 1969 radiator support?? if that makes a difference.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Baged72 is offline   Reply With Quote
Old 01-26-2010, 11:04 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: How do I install headlights??
baged72... check out this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=360904
You should have a headlight bucket which is attached to the firewall.
Then you plug your bulb in and push the blub into the bucket
Then you install the bulb trim ring (chrome ring) around the blub which then screws into the headlight bucket.
Last you install the headlight bezel
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-26-2010, 11:28 PM   #3
Kayotic
Kayotic's Avatar
Yup, the square holes are where the adjusters go. They clip in from the back, screw pointing forward.
Just watch the springs though, I thing they are different at some point between the years. Atleast in the adjustment kit I bought for my '70, the springs don't seem right...
Do the springs change per model year?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 01-26-2010, 11:50 PM   #4
Baged72
Baged72's Avatar
Hmm headlight bucket that is what im missing, is that all i need to get some lights installed? What is this spring Kayotic talked about?
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
Old 01-27-2010, 12:13 AM   #5
Kayotic
Kayotic's Avatar
Here's an exploded view from LMC TRUCK page 162
From the looks of it the springs are the same. Maybe I have the same problem.
Atlanta Craigslist
Old 01-27-2010, 02:14 AM   #6
Baged72
Baged72's Avatar
I got it, a fellow board member here had a set laying around with full hardware for $20, just picked it up.
72 GMC SB
Built 400 SBC
B&M TH350
12Bolt Posi 4:11
Bagged
