Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-26-2010, 10:31 PM   #1
carter442
88 k2500 radio probs
i just installed a radio in my k2500 and i hooked the antenna wire up but i cant pick up radio stations what is the fix for this? i figured if i got a new antenna and installed it it would help. and after installing it and listening to cds my left sie speaker stopped putting out sound it is kind of fuzzy when music should come out of it and it is very quiet i assume its gone out am i correct?
carter442 is offline   Reply With Quote
Old 01-27-2010, 10:13 PM   #2
dirtyd_nd
Re: 88 k2500 radio probs
Push on the speaker. If the sound gets louder, it's a goner. If not, check the wires that go to that speaker. As far as the ant. Did you get the adapter that hooks the ant wire into the aftermarket head unit.
dirtyd_nd is offline   Reply With Quote
Old 01-27-2010, 10:20 PM   #3
carter442
i got the metra adapter that plugs into the factory wireing harness i didnt havbe a spot on it for the antenna
Old 01-28-2010, 09:35 PM   #4
dirtyd_nd
This is what you need.http://www.amazon.com/40-GM21-Antenna-Adapter-Barb... http://www.amazon.com/40-GM21-Antenna-Adapter-Barb...
