Old 01-27-2010, 12:51 AM   #1
nrb's70gmc
nrb's70gmc's Avatar
stock doors with modern door panels
When i get to the project, i want to have a ultra modern interior and one of my questions is.
if i use a inner door panel from a newer truck (2006+) and (besides the cutting & art work involved to do it)
with the newer truck panels, the location of the inside door handle will be moved
basiclly i want to know if this would be a fairly staight forward project, to connect the old with the new, make the new door handle work with the stock door latch?
sorry if its confusing i did'nt know how to explain it. i have not had my door panels off before so i can visaulize it. are the stock inner door panels cable opperated? in 67-72 trucks?
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 01-27-2010, 12:53 AM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: stock doors with modern door panels
They have metal linkage.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 01-27-2010, 12:55 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I would say it would be a lot of work to do that. You'd be better off to try and make custom door panels out of fiberglass and wrap in whatever you want. The door mechanics are rod operated. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-27-2010, 01:00 AM   #4
Zoomin
Man of Mini-Talents
Zoomin's Avatar
How about converting to electric using a 3rd party kit?
Zoomin is offline   Reply With Quote
Old 01-27-2010, 01:13 AM   #5
nrb's70gmc
nrb's70gmc's Avatar
i want to do power locks, and windows as well-i guess i will need to wait to get a good look at a door with out the panel on it to figure out my game plan.
Old 01-27-2010, 01:30 AM   #6
Smallz72project
Smallz72project's Avatar
Im sure it can be done, probably have to modify the newer panel more then the door itself though...but in regards to the linkage you could probably set up a method for it to work with a couple cams. Picture kinda shows a little better of what I mean, the red is obviously the handle and the door latch, blue is your linkage, metal triangles are the cams and the arrows indicate which way the rod would be pushed or pulled....just an idea that might help you along your way. Another way might be to take the door inner framing/skin off of a new truck and weld it into the 67-72 door frame and just relocate your striker on the B pillar?? Best of luck with it.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 01-27-2010, 01:40 AM   #7
nrb's70gmc
nrb's70gmc's Avatar
thanks for that, that is just what i needed to see, it will be a while yet, but know i have more of an idea. Thanks
Old 01-27-2010, 11:01 AM   #8
idonutn0
How about this idea, take the late model door, cut out the metal where the modern door panels, handles and window regulator are with all of this still attached, then use this as a template to cut up your 67-72 door, cut that out and weld the late model metal in. This way the late model mounts for everything are in place and all you have to figure out is how to attach the late model door handle to the older door release and the push lock mechanism.
It would be a LOT of work but it might be pretty cool and see some late model S-10 style door panels on one of our trucks.
idonutn0 is offline   Reply With Quote
Old 01-27-2010, 01:08 PM   #9
nrb's70gmc
nrb's70gmc's Avatar
Ya that was some what my idea, because i also want to do the same thing with the outside door handle (move it down and use late model flush mounted door handles) so it would be a project lol, but you can build anything with the right tools.
