01-27-2010, 04:41 AM | #1 |
69-72 GMC with 67-68 hood
anyone have pics of this done?
72 GMC Suburban (former ambulance), soon to be set atop a 2009 SIERRA K2500 chassis w/6.0L&4L80E |
01-27-2010, 04:06 PM | #2 |
Re: 69-72 GMC with 67-68 hood
It's a direct bolt on...but I don't think the hood lines up with the newer grills
02-01-2010, 03:08 AM | #3 |
You have to remove the grill lip, its the chrome piece that mounts on top of the grill that fills the gap for the 69-72 hoods. Fenders will be the same. The grills do have some differences through all years, but should work. Please correct me if I am wrong gentleman of the board. My 70 came with a 68 front end and I converted it back right. I had to get a lip to close the hood gap. Good Luck on your pictures.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
02-01-2010, 03:18 AM | #4 |
Here is my hood now with the lip circled for you. You can barely see my red circle, but it is the part under the hood and the GMC letters, thats the lip. You will have to change your eyebrows too. The 67-68 truck eyebrows were thinner. They are what goes on the front of each fender finishing the trim option of the lip. Lips are normally rived, but I have seen them bolted also. The eyebrows should pull right off unless someone put screws in them to hold them on. Hope this helps ya.
R/ Billy
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 02-01-2010 at 03:24 AM. |
02-01-2010, 03:30 AM | #5 |
Here is a better look. You remove that lip and that 67-68 hood will mate perfect with the front grill.
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 02-01-2010 at 03:31 AM. |
02-01-2010, 03:36 AM | #6 |
Here is an example of a 68 grill with no lip. What you do see is the hood trim that comes on the 68 hoods. Notice the different, skinnier eyebrows also. This is what your truck will look like with with a 68 hood and proper eyebrows.
R/ Billy
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! Last edited by longhorn70gmc; 02-01-2010 at 03:37 AM. |
02-06-2010, 03:39 PM | #7 |
There is a different grille top bar that you are going to need that is only for the 67-68 GMC, otherwise there will be a gap between the hood and gille. Also, going to need a new hood latch assembly. i just did this to my 70.
02-07-2010, 12:47 AM | #8 |
I am almost done this on my '72 Blazer, I cut about 1 1/2 from the hood leading edge then welded the '72 inner to the '68 hood.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
02-07-2010, 10:22 AM | #9 |
member
Hey Phat Tony, I like it !!!
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
