low n' slo
![]() Join Date: Mar 2009
Looking for this cab piece
I hope this isn't a long shot..I need the area inside the door area at the top..its the curved piece that the top that the door frame slams against (passenger side). mine is a suburban but im sure a truck piece will work. I will post a pic when i get off of work..let me know if you have it. thanks
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
![]() Join Date: Sep 2009
Re: Looking for this cab piece
I am cutting the firewall off a wrecked rust free cab for Steve (zoomin) and could get the piece you need at the same time. Go ahead and send picture to confirm what you need.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
low n' slo
it was too dark to get a pic tonight but i need the top part behind this part of the door...
low n' slo
here we go..i took one with the flash on..i need it the length of the door frame, pretty much the whole thing lol
Thanks, that helps alot. I will cut a section larger than you need so you will have plenty of room to work. the section is really a very small amount, most of it will be labor, how does $75 sound then we will figure out how to get it to you? Where is Rosenberg?
Paul
low n' slo
hmm..i might have to get back with you. from the holes it looks like it goes all the way across, but i might wanna try to weld up the holes and see if that will work.
