Old 01-27-2010, 08:49 AM   #1
gmcdude
gmcdude's Avatar
Fuel Tank
Those of you that have used a Surburban fuel tank on the short bed tank relocation. What size was it? Year? And did ya have to notch the bed support?
gmcdude is offline   Reply With Quote
Old 01-27-2010, 01:21 PM   #2
chuck3026
chuck3026's Avatar
Re: Fuel Tank
I found this info here...
Dynomutt, here is the info. About 5-6 inches. Not lower than the diff. I bought mine used for $80 with the Mallory fuel pump and 18ft of S/S braided hose, what a deal! You can pick one up from Summit Racing. It's a 16 gallon, for about $153.00. Here is the part number SUM-290108.
http://store.summitracing.com/partde...5&autoview=sku
chuck3026 is offline   Reply With Quote
Old 02-04-2010, 09:14 AM   #3
gmcdude
gmcdude's Avatar
Re: Fuel Tank
Thats good but where do you put the fuel in? I'm really looking to use a Surburban tank thanks
Old 02-04-2010, 10:51 AM   #4
chuck3026
chuck3026's Avatar
Re: Fuel Tank
Up through the bed floor usually but can be routed out the side
2006 Crew cab Z71
1972 Short Wide Step (under construction)
Old 02-05-2010, 01:12 AM   #5
Strut
Strut's Avatar
Re: Fuel Tank
I used the same Summit Tank and this is what I done:
Mine sets alittle higher then in the one in the other picture.....
I notched the last cross member under the bed to get the filler cap closer to the floor....
Here is my fuel door.....
I hope it helps....
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 02-05-2010, 11:41 AM   #6
Larry S
Larry S's Avatar
Re: Fuel Tank
Is that tank steel or plastic? Does it come with tank and sender? Also can you get it with differect pumps Need higher pressure pump for vortec.
Larry S is offline   Reply With Quote
Old 02-05-2010, 03:37 PM   #7
Strut
Strut's Avatar
Re: Fuel Tank
Tank comes with sending unit. It is Poly. Plastic. Dosent come with a internal fuel pump.
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-09-2010, 06:18 PM   #8
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
Looks like my pic was used! Here are some pics of how I am putting the fuel in.
I had the muffler shop weld in a 2.25 inch pipe.
I measured to the center of the fuel cell filler hole.
Had the muffler shop bend a 45 to clear the sending unit.
Lowered my tank down a little with spacers in the back to give it more room.
Cut the crossmember to run the pipe. It comes out about 7-8 inches behind the rear wheel well in the bed and about 5-6 inches away from the side.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-09-2010, 06:24 PM   #9
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Fuel Tank
hey slick is that a blazer tank? wat'd ya use for a filler door? Id make mine come out the floor but i use the truck as a truck and dont wanna unload to fill up lol
John
1999 Toyota Tacoma 4x4
Old 02-09-2010, 06:34 PM   #10
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
It is a tank from summit racing 16 gallon. I am using a 45 degree filler neck, it is going to be close to the side so it won't get in the way, too bad. As you can see in the second pic, the placement of the filler neck can be where you want it just by cutting the pipe length. Just bend it at a 90 or use rubber to go through the bed floor.
Old 02-09-2010, 07:02 PM   #11
oldblue1968chevy
Re: Fuel Tank
i like i like alot...may have to copy it!
did you have to go up after the 45*
John
Old 02-09-2010, 07:08 PM   #12
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
I will be using a 90 degree hose to a fuel filler neck, probably the 8 inch JAZ Products neck. I like the look of them.
Old 02-09-2010, 07:12 PM   #13
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
It is actually right on the bottom of the bed floor right where the hose is and I wrapped some camper seal tape around it to keep it from rattling. I will make a bracket to hold it up, but it has to be removeable incase the bed needs to come off at a later time for some reason.
Old 02-09-2010, 08:34 PM   #14
oldblue1968chevy
Re: Fuel Tank
link to your thingy you like the filler thing? or pic or more info lol is it $$$
John
Old 02-09-2010, 11:01 PM   #15
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Re: Fuel Tank
Attachment 545230
Attachment 545231
Attachment 545232
Attachment 545236
Attachment 545237
Super nice setup. I'm gonna give it a shot.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-09-2010, 11:09 PM   #16
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
Jegs has them, but I think they are a little less if you look around, maybe RCI?? Here is the link.
http://www.jegs.com/webapp/wcs/store...iller%2520neck
shot.
Thanks! Took a little figurin' but thought it would be the best way to run and look clean at the same time.
Old 02-10-2010, 12:01 PM   #17
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
This was the cheapest place I found on the web and just ordered my 8 inch 45 degree filler neck.
http://www.outperformanceshop.com/pr...345-252-03.htm
Old 02-11-2010, 06:59 PM   #18
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
Bump.
For other link.
Old 02-12-2010, 09:32 PM   #19
tk-mpl
tk-mpl's Avatar
Re: Fuel Tank
looks good.. do you know if this tank will work for fuel injected engines??
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 02-13-2010, 10:19 AM   #20
Strut
Strut's Avatar
Re: Fuel Tank
The tank does have a fuel return fitting and sending unit in tank. But doesnt have a internal fuel pump. I think that it would work for fuel injection, but you would have to run a external fuel pump.
1972 Chevy C10 SWB
2008 Yamaha R1
Old 02-22-2010, 07:34 PM   #21
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: Fuel Tank
Alright guys, here is the filler neck. I will have a peice of 2 inch pipe about 3.5 to 4 inches long welded to the bottom ( and cut as needed) then install a 90 degree hose to it that will attach to the pipe under the bed. That's it! I will post pics on here after the final install is done and with the bed back on.
