01-27-2010, 09:11 AM | #1 |
No Tranny Fluid in 05 Tahoe !! HELP ME OUT
OK so I bought this Tahoe with 45K on it about one month ago Aprox 2500 miles since I bought it. Today leaving work the truck seemed to miss or slip a little. So when I got home I checked the Tranny fluid. The stick was dry! I checked under the truck from the front to back. Everything is clean. Looks brand new. I started adding fluid to the tranny and running it through the gears. I then would shout it off and let it sit for 1/2 hour. I started it up and warmed it up and checked it, long story short I added 1 1/4 qrts of fluid and its just at the bottom of the hot check marks. I drove it in again to work and checked it right after driving and its still at the bottom of the check mark.
Any help ? Suggestions?
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. |
01-27-2010, 09:34 AM | #2 |
Redefining LowBudget
Re: No Tranny Fluid in 05 Tahoe !! HELP ME OUT
fill it and then check it ...alot..also check your rad to see if the cooler is leaking....if not and your still loosing fluid its probably getting sucked out though a vacum line
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
01-27-2010, 09:42 AM | #3 |
No leaks up front that I can see. Does the vacum line go out the top of the tranny? Like I said there are no wet spots on the truck. I park it on concrete and no puddles.
Were does the line end up? Ill try and check that tonight
01-27-2010, 09:46 AM | #4 |
it will be hard to see it in a vacum line...I would guess you have a 700 or 200 trans and I don't know enough about them to know where it comes out of the trany but they all end up pulling vacume from the intake usually in the back....someone will jump in I'm sure
01-27-2010, 10:35 AM | #5 |
tranny is the 4l60E. I sent the reply with out thinking much about the vacumm line. I would be blowing smoke because it would go directly into the combustion chamber. So thats not a issue. Well maybe someone will have a idea.
I ran this truck for about 2500 miles since I bought the truck. Not sure when the leave was down as I checked it at test drive. do you think I did alot of damage ?
01-27-2010, 10:44 AM | #6 |
don't be fooled by the lack of smoke it would be in such small amounts you wouldn't notice
01-27-2010, 12:56 PM | #7 |
Theres no vacuum line going to a 4L60E. Like hottrucks said, check the radiator for trans fliud floating on the top of the antifreeze. Are you sure there is no external leaks.
A word of caution.......... DONT drive your truck low on trasmission fluid. The number one killer of a 4L60E is low fluid level. Last edited by clinebarger; 01-27-2010 at 12:58 PM. |
01-27-2010, 09:00 PM | #8 |
What he said. Look real close at the rear seal on the tranny, tranny cooler lines, trans fluid in the radiator and front of trans at the bell housing.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
01-28-2010, 09:15 AM | #9 | |
I guess the transfer case is has lower pressure so the tranny fluid seeks the path of least resistance. Dealer is fixing under warranty
01-28-2010, 09:25 AM | #10 |
Nice find...
Just be sure to note on your paper work that the trans was run low on fluid...maybe ...If...you have a trans issue you can fall back on the paper work to get them to help out $$$
01-28-2010, 10:19 PM | #11 |
i glad you got it fixed!
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-29-2010, 10:01 PM | #12 |
Good to hear that they are fixing it.
02-03-2010, 01:16 PM | #13 |
well got it the tahoe back. I was looking the job over and there seems to be some oil from the back of the tail shaft. ITs not tranny fluid but oil like. I wioed it off and checked for two days. Nothing leaking out. Could this have been assembly lube?
2013 Chevy Silverado, Z71, 5.3L, 4 door 2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40 Support the Troops. Last edited by remist17; 02-03-2010 at 01:25 PM. |
02-03-2010, 02:30 PM | #14 | |
, its a good thing dont worry about it |
02-04-2010, 11:38 AM | #15 | |
yea i cleaned it all off and seems not to be back .... feeew. Seems to be all working well. The dealer actually took it back to the Chevy dealer for the work to be done. So I feel better about that.
