01-27-2010, 06:06 PM | #1 |
Anyone had luch with repairing a/c diverter flap?
Hi,
Has anyone had luck with repairing the a/c diverter flap? Mine is broken just below the pivot all the way across and the only thing holding it on is the rubber gasket. I thought about gluing a piece of aluminum across the crack. Thanks in advance for any help!
71 C-10 "Ole Blue" 72 C-15 - Current Project 72 K-10 - In Pieces (Sold) 70 C-10 - "Goldie" (Sold) 66 Impala Convertible 20 FLTRXS |
01-27-2010, 06:34 PM | #2 |
Re: Anyone had luch with repairing a/c diverter flap?
I fixed mine with epoxy. The kind that comes in a roll and you knead in your fingers until it is one color. It was a pain because I tried to get some into the crack (actually peeling up the rubber a bit) and then a good skim coat on both sides with a little running up the two sides. It has held for 6 months so far. I have a NOS one on the shelf for when it fails which it probably will.
Good luck. I found my new GM one on ebay for about $95 shipped.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
01-27-2010, 07:01 PM | #3 |
I had the exact same problem. I JB Welded mine and haven't had any problems. Some aluminum and small screws for reinforcement wouldn't be a bad idea either.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) You've gotta be able to stop and steer before you can go fast! |
01-27-2010, 08:44 PM | #4 |
Here's how I did it, and it works great for lots of repairs:
Clean and rough up the surface. If it's a small surface area, I drill some small holes to let the epoxy get a better grip. I lay on a thin coat of JB Weld and lay fiberglass cloth across it while it's wet. Then I put more JB weld on top of that. If you need to you can sand it or file it or even trim it with a utility knife. I've never had a plastic repair I've done like this fail. |
