Old 01-27-2010, 09:40 PM   #1
dan468
dan468's Avatar
Hydraulic Clutch in 67-72 chevy truck????
I would like to put a hydraulic clutch in my pick up from an F body, has anyone done this or have any ideas on how we can accomplish this??
Thanks!!!
Dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 01-27-2010, 10:18 PM   #2
Re: Hydraulic Clutch in 67-72 chevy truck????
Why?I hate hydraulic clutches.Is there a problem with the original linkage?Didn`t think so.I`ve never had a problem.I`ve had plenty of problems from hydraulic,though.I was looking for a way to change it to good old fool proof linkage.They always put the slave cylinder on the passenger side.
Old 01-27-2010, 10:23 PM   #3
joeelutz
joeelutz's Avatar
Yes I did one for a customer in a 70. He was running a 5 speed and we used a Wilwood master hooked to the stock pedal. I had to drill a hole higher than the stock one in the pedal arm to get the correct pedal ratio, but it worked great.
joeelutz is offline   Reply With Quote
Old 01-27-2010, 10:25 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
A couple of people on the board have done it. I have never had one so can't comment on the good/bad ratio...
If you type - hydraulic clutch - into the Google Search box above and tick the 67-72chevytrucks.com circle you will get lots of info on it.
LockDoc
Leon
Old 01-27-2010, 10:40 PM   #5
dan468
dan468's Avatar
I just realized there's a ton of info on the search. Seeing as you've already done one, however, can I contact you if I have any problems? BTW the reason for it is a t56.
Thanks!
Dan
68 C-10
Build thread
Old 01-27-2010, 10:48 PM   #6
joeelutz
joeelutz's Avatar
Thanks!
Dan
Sure, not a problem. I just put a T56 in a 67 Camaro with hyd clutch and fabbed a custom mount for the master cyl.
Is it ok to post my email address?
Old 01-27-2010, 10:49 PM   #7
msgross
msgross's Avatar
Musclerodz did it on his last K-20 build... They used an NV4500 as well..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-27-2010, 11:50 PM   #8
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm going to be doing one on my Longhorn as well and will post up how it goes once it is in. I don't see what people's problem with hydraulic clutches are? Once they are bled they are nice to operate and easier to operate. Trust me, any of you have any trucks with 4200# pressure plate loads? Push that with the stock type pedal set up.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-28-2010, 01:11 AM   #9
dan468
dan468's Avatar
I think I might go to a hydraulic throwout bearing system
68 C-10
Build thread
