Old 01-27-2010, 11:47 PM   #1
54Caddy
GM Addicted
54Caddy's Avatar
steering problem
on my truck when i turn almost a full turn my truck skips in a way, feels like it jumping out from under me, some people tell me its my tie rod ends, which i can see thats the only thing thats not new on the suspension, could it be that??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 01-28-2010, 12:05 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: steering problem
it could be tie rod ends, bushings ball joints or the steering box. You need to jack up the truck and check out what lies underneath
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-28-2010, 12:09 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
all bushings are new poly urathene, ball joins are all also new, and dont say steering box hope not damn things are pricey
..Mac’s Garage..
IG:MacsGarage
Old 01-28-2010, 12:43 AM   #4
1LowToy
I would check wheel bearings ASAP! You may have one that is real bad. If wheel bearings are good you have an alignment issue. Incorrect castor will change the turning radius from right to left full turns and cause scubbing on turns. Has the truck been lowered and if so how (spring, spindles or both)?
1LowToy is offline   Reply With Quote
Old 01-28-2010, 12:51 AM   #5
54Caddy
GM Addicted
54Caddy's Avatar
trucks lowered i believe springs are cut, so you think wheel bearings?? also when i get around 50 i get a vibration from the front passanger tire, could that also be wheel bearings??
..Mac’s Garage..
IG:MacsGarage
Old 01-28-2010, 08:36 AM   #6
1LowToy
Yes. also check your tie rods and idler arm. Lift te wheel to check the wheel bearing. Check the Idler arm and entire drag link for wear. Have someone turn the steering wheel slowly left and right about 2 to 3" and look at the tie rod ends and idler arm for wear. It sounds like you may have an issue there. I.e. when turning a slow sharp left like into a parking place your right front tire is turning further left than your left tire causing it to skip or scrub across the pavement. Some scrubing may be predictable even with good suspension components but a bad idler arm could make it worse. Lowering with springs alone changes your former alignment and steering geometry drasticly.
Old 01-28-2010, 09:50 AM   #7
grinch4om
dang its hot
grinch4om's Avatar
have it aligned
grinch4om is offline   Reply With Quote
Old 01-28-2010, 09:57 AM   #8
old Rusty C10
wheel bearings are a strong possibility too...but again the easiest way is to jack up the front and check it out
Bob
I hate cancer!!
Old 01-28-2010, 10:56 AM   #9
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
hey 54caddy i know its off the subject but how do you like the poly suspension? i wa thinkin bout getting that for my truck too.
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 01-29-2010, 01:54 AM   #10
54Caddy
GM Addicted
54Caddy's Avatar
the poly is good nice and stiff man, and i will check the tie rod ends when i look what do i look for??
..Mac’s Garage..
IG:MacsGarage
Old 01-29-2010, 05:09 PM   #11
oldschool18
oldschool18's Avatar
50 is a good speed for a wheel bearing to start vibrating
oldschool18 is offline   Reply With Quote
Old 01-29-2010, 09:24 PM   #12
54Caddy
GM Addicted
54Caddy's Avatar
alrite so should i repack them or check them out and see if there any good
..Mac’s Garage..
IG:MacsGarage
Old 01-29-2010, 09:35 PM   #13
MR .T
MR .T's Avatar
Excessive play, you should not be able to move them much at all with your hand if it feels loose at all they are bad. Also whaen you jack it up grab the tire with your hands and wiggle it from side to side see if it feels loose.
MR .T is offline   Reply With Quote
Old 01-29-2010, 10:15 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
If its lowered with cut spring like mine. The front suspension geometry gets really bad at full lock.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-29-2010, 11:09 PM   #15
54Caddy
GM Addicted
54Caddy's Avatar
yea i know that it messes up the geometery but this just recently started happening and it was lowered this way way before i built it..
..Mac’s Garage..
IG:MacsGarage
Old 01-30-2010, 12:02 AM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Make sure the frame hasnt cracked at the steering box mount. My 77 with 10" wheels in front broke the frame and made some awful popping noises
Old 01-30-2010, 09:35 PM   #17
54Caddy
GM Addicted
54Caddy's Avatar
hahah mine already cracked its fixed rite now with four thick plates of metal squeezing the frame till i can afford the frame piece and weld it in, maybe the steering box came a little loose.. idk im going to check wheel bearings tomorrow if the weather is good..
..Mac’s Garage..
IG:MacsGarage
