Old 01-28-2010, 12:54 AM   #1
drewfever1020
whos had?
one of the bolts that tightend the transpan to the tranny strip before?
how did u fix it?
drewfever1020 is offline   Reply With Quote
Old 01-28-2010, 01:04 AM   #2
Boog
laying low
Boog's Avatar
Re: whos had?
Aluminum housing, no problem. Go to parts store and check out a helicoil kit. Fix it right up.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-28-2010, 01:12 AM   #3
drewfever1020
Re: whos had?
ya i have a kit but i didnt know if it would crack when i make the new threads
Old 01-28-2010, 02:16 AM   #4
tim21391
tim21391's Avatar
Re: whos had?
on my doors when they stripped out i welded it shut.. drilled a pilot hole then used a bigger bit and redrilled it and threaded it.. u can try same way with the housing just switch to a spool gun aluminum welder..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-28-2010, 03:22 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
Re: whos had?
easy fix, take a small carter key and unfold it put the unfolded part in the striped out hole and start the bolt in there and your done till you have to change it again .
not the best fix but it works , i worked part time at a trans shop back in the late 70s and thats how they fixed them
tnblazerk5 is offline   Reply With Quote
