Old 01-28-2010, 01:22 PM   #1
bestchevyfan
Engine[six] ????????
On a six how can you tell the size [c.i.] thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 01-28-2010, 02:29 PM   #2
john
member #16
john's Avatar
Re: Engine[six] ????????
By looking at them the 292 has taller side covers than a 250 and different r.h. motor mount placement.
john is offline   Reply With Quote
Old 01-28-2010, 05:06 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
what kind of six? there were also 305 V6 and 351 V6, but these were much less common.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-28-2010, 05:14 PM   #4
68lwb292
Ex-Minitrucker
68lwb292's Avatar
got a pic of it? Like John said if its a 250 the motor mounts will be in the middle on both sides. If its a 292 the Passenger side motor mount is moved forward in front of the fuel pump, staggered from the drivers side. On the 250 the fuel pump and motor mount is opposite of the 292.
Here's a 292.
Here's a 250
68lwb292 is offline   Reply With Quote
Old 01-29-2010, 10:53 PM   #5
pritch
pritch's Avatar
Or, you could do what I did and tear it all down to find a broken piston, go buy a new piston, then discover that some PO had slipped in a 230 in place of the 250 (Different pistons, of course)
But it got worse. After getting the correct piston, I decided to do the bearings while it was apart. Since there were no oversize markings on the old bearings, I assumed they were standard and bought same. Got it all put back together and back in my Panel. The dang thing started up on the first crank and life was good-but-5 pounds of oil pressure! Sure enough, the crank had been ground 10 under.On the bright side-I have a whole set of standard size bearings with 5 minutes on them, and a brand new 250 piston
Moral to the story: (and it's been said over and over) Never assume anything!!!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 01-30-2010, 12:37 PM   #6
68 C-10 Panel
68 C-10 Panel's Avatar
Yes, never assume anything...!!!! Ha I posted some questions up here a while ago about a vacuum issue I was having and didn't get one response. So being the persistent bastard I am I trudged on blindly. By the time I tracked down the little -temp vacuum switch- with the 3/8"npt not the 1/2"npt, I with the help of the napa guy came up with some crappy info. Now this is my first 67-72 chevy so its all been a learning experience. Anyways the P.O. switched the darn head on my 250 with a integral head off a 73-79 Nova. Just what I needed another boat anchor. Thats why there was no hook up for the manual choke.But no big deal, a $30 switch sets me off to get a 300 dollar head and I can return it to original. Oh and did we mention ......never assume anything
68 C-10 Panel (fixing) 250-6,3ott
93 k1500 pickup DD
"When a man is old enough to figure out his dad was right, he has a son who thinks he's wrong" Charles Wadsworth
68 C-10 Panel is offline   Reply With Quote
