Old 01-28-2010, 04:27 PM   #1
playinsafe44
Which Trans?
I thought I was going to put a NV3500 in my 73' 1/2 ton longbed, but now I'm not sure. I want to keep the 250 in it, and probably the 3.73 gears too. Just not sure if I should go with an NV3500, a 200r4 or a 700r4. I want to be able to do some light towing (travel trailer, small boat, load of wood, etc.). I like the manual, just not sure if it will be the best for gearing and MPG (I want the option that gives me the best MPG possible). Any thoughts?
playinsafe44 is offline   Reply With Quote
Old 01-29-2010, 12:19 AM   #2
TwoFiftyShifter
Re: Which Trans?
I think either one will give you big mpg gains, but neither one moreso than the other, Auto OD or 5-speed. And, of course, a stick is cooler on an old truck.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-29-2010, 09:57 PM   #3
playinsafe44
Re: Which Trans?
I think I am leaning towards the NV3500. I'm just a wondering if there will be any issues getting a clutch combo together. I would need to look into some kind of clutch master cylinder too. Is there an easy way to convert the gauges to electronic? Could I just swap in a later square body cluster?
Old 02-02-2010, 10:24 PM   #4
playinsafe44
Re: Which Trans?
Anybody have any tips or suggestions for swapping in an NV3500 into one of these trucks? What was your solution for the speedometer, clutch master, clutch/pressure plate, and driveline? Any tips would be great. Right now I'm looking at about $250 for the tranny alone. Is that reasonable?
Old 02-02-2010, 10:40 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Which Trans?
Check over at www.coloradok5.com for a conversion.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
