Old 01-28-2010, 05:39 PM   #1
vegaschevy
upper and lower control arm shafts
I have found the torque is 130 lower and 95 upper.
my question is my front nut seems to rotate with the arm up and down. The lower nut does not.
why? should I some how fix this?
I am not sure 100% on the proper procedure for installation but I tried to screw on both nuts an equal amount.
vegaschevy is offline   Reply With Quote
Old 01-28-2010, 06:15 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: upper and lower control arm shafts
Once the nuts are threaded into the arm and cross shaft, the nuts will rotate with the arms as one unit. They are riding on the internal threads of the nuts, on the cross shaft thread.
If you have the lower nut tightened and keeping the cross shaft from spinning, the lower nut does not move up and down with the rotation of the arm, you have a major problem.
Think of the nuts as being one piece with the arms once installed.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-28-2010, 06:51 PM   #3
70stroker
70stroker's Avatar
man i hope you figure this out fast so we can see that truck on the ground tonight.
wish i had the answer for ya.
70stroker is offline   Reply With Quote
Old 01-28-2010, 06:55 PM   #4
vegaschevy
It was threaded on and off easy, It is not binding and not stripped.
why could it not be tighter on the shaft and stay still with the center shaft and have the control arm pivot around it?
Also front to back how do you make sure both nuts have equal tension. For example front to back.
They are both torqued properly btu was wondering if you could have one threaded on the shaft further on one side. Like the one that is not spinning may not be on as tight or vice versa
Old 01-28-2010, 07:01 PM   #5
Normy71
Is this the reason some people tack weld them?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 01-28-2010, 11:33 PM   #6
vegaschevy
Pretty easy fix, I found that the stationary cap was bottoming on the shaft and not the arm. Make sure your arm is center when you start screwing the caps on
Old 01-29-2010, 12:45 AM   #7
chevy_mike
chevy_mike's Avatar
Glad you got it sorted out.
